How much horsepower with addition of Dynomax super turbos
I have a l-48 that is bone stock and decided replace the original mufflers this year, I put on Dynomax super turbos and would like to know as a base how much more hp these mufflers really add ?
Thanks
Thanks
Re: How much horsepower with addition of Dynomax super turbos (RATT7)
anytime you increase the flow through the system, you gain power. and the superturbos flow very well. just bolting on the mufflers +5-10 hp. with 2-1/2" duals +20 hp. with headers... :D
The Dynomax mufflers will probably offer less back pressure as compared to stock. Less back pressure means less low end torque. The L-48 might not make enough power/exhaust to take advantage of the new muffler. Overall performance could have decreased.
I doubt you'll feel the difference between these new muflers and your stock ones. Get them for the sound you like, not HP (with a stock engine). I removed my stock mufflers and installed straight-thru Edelbrocks, and the only difference is the sound. IMO, all the talk about muffler CFM flow is a bunch of hot air when you're still running stock manifolds and pipes.
