lock up torque convertor switch
Re: lock up torque convertor switch (corvettemaster)
Sallee Chevrolet
High Performance 4L60 Four-Speed Automatic Transmission
Installation Instructions
http://www.sallee-chevrolet.com/Chev...tallation.html
I think that the part you are looking for is at the lower right corner of the web link that I provided.
P/N 24502513 - Switch Kit, GM instruction sheet (source for this page), 4 and 5 pin TCC connectors, Pin Extraction Tool, TV spring, fourth gear clutch switch (P/N 8683502), and 2 small GMPP decals.
OOPS>> I misread your post. I had 700R4/4L60 on my brain. Sorry. :crazy:
[Modified by MIKER, 5:20 PM 11/19/2001]
Re: lock up torque convertor switch (MIKER)
Thanks for trying :D
I have the original transmission, which I believe is the TH-350C. Was thinking about converting to the 700R4, but haven't decided. I believe I will just stick with the 350C, if I can get the torque convertor working...for fuel economy purposes...i only get 13-14 mpg right now :( :(
Ok, I'll try again. I looked in my 1980 assembly manual and it shows the part # 14008246. No guarantee here but maybe that number will work for ya!:seeya
Thanks for the help. I need to change my transmission fluid, so while i am doing that, i am going to take the switch out and compare the # on it to the one you gave me.
[Modified by corvettemaster, 10:17 AM 11/20/2001]
