Disappearing coolant...
Cruise-In IV Veteran
St. Jude Donor '03-'10
I'm continually having to refill the coolant on my car. I've never noticed a leak anywhere and there is never coolant on the garage floor.
No coolant in the oil either that I can tell.
Pretty much means I'm burning off coolant, I'm guessing.
Now...there is a really bad cap on my coolant overflow tank (cracked in several places)...is it possible the water is evaporating from that tank and disappearing? I'd love it if just putting on a new cap would clear up this problem. :D
If not, is there somewhere to start looking to see if and where I might be burning off coolant?
Re: Disappearing coolant... (Chris Fowler '80)
Get your radiator cap tested and replaced, if necessary. If it is good then I would suspect a head gasket that has a small hole in it. Do a compression check to see which one.
Gary
Gary
Re: Disappearing coolant... (GaryS)
Where can I get the radiator cap tested?
Do I have to take it to a radiator shop or can it be tested at other places?
I'd be surprised if a compression check could pick up the pinhole you probably have in a gasket. Also, I think I read somewhere that certain heads are prone to cracking (around the exhaust ports?); I suppose it's possible that something like that might have happened too.
Re: Disappearing coolant... (Frank75)
Well...the one thing that makes me think it might not be the heads is that it's been doing this since I got the car (in April) and I had the heads completely rebuild in July...
