nitrous in a stock engine
Sorry for the duplication of topics, I didn't see the recent post of Markus P. I might as well just ask some q's here.
Is this a bad idea for a 50 to 100 HP shot? If it is a bad idea, what are the bare minimum items that need to be beefed up? Pistons, rods, crank, etc? I'm on a tight budget, but would like to try it out. BTW, the engine I'm talking about using is a non #s matching engine, just a normal old 350cid - cast pistons, 8.5:1, etc. Although I would be changing the cam. Would it be a better idea to run one of the N2O cams with just 50 to 100 HP shots, or would a regular grind be just as good (262, 268, etc.)?
Also, is it good to have a bit lower compression for Nitrous like it is for super/turbo charging? Thanks in advance for the input.
[Modified by EIGHTDOLLARS, 10:41 AM 11/19/2001]
Re: nitrous in a stock engine (EIGHTDOLLARS)
You can fit 50-100 HP on any stock engine. You DO NOT need anything special. Give it a try but don't exceed that 100HP. I have installed at least 6 for the local kids and some of them destroy transmissions and tires on a regular basis and I have never seen them destroy a motor with nitrous. I keep all jets and only give then 100horse.
Even 15-1 compression motors run nitrous. Don't worry about compression on stock motor. Hooked up properly it is safe.
A motor started on nitrous starts faster then you can turn the key but that is where you get explosions.
Good luck and try it you will like it.
you should be fine with that amount...say under 100 or 125 nitrous add-on..
differs with who you ask...but definately no more than 125hp....
stock is fine...healthy is better...
I have spoken with people who used it on engines with 100,000 miles before they got the car and used nitrous and never had an issue....all depends on how you *use it* or *abuse it*.....
sound engine with a lil' juice shouldn't be an issue...also on the cam
issue...go the normal grind unless you want to get addicted to the juice and ar thinking of going more juice down the road.....but then the whole engine and drive shaft will need to be beefed up....(edit) drive shaft I mean....over 125 hp and your realling slamming the drive shaft/rear end...so if they are aged they may break... :lol: )
yes lower compression is better....over 11:1 I think is the mark....and you need the interior beefed for NOS plus some other issues....but you aren't into that issue....YET ? :yesnod:
[Modified by ylose, 12:30 PM 11/19/2001]
Re: nitrous in a stock engine (Neo Fender)
I would add a caveat to this. A HEALTHY stock engine. I would think twice about adding N2O to an engine has many miles or years on it.
:cheers:
