Need Block ID help please...
It's a 350 casting 3970010 with 4 bolt main. Back of block has 262. Stamp pad says V1106TJZ (no serial number). I can get head / intake and other numbers if that will help ID what this "junkyard special." Thanks, ~Juliet
Re: Need Block ID help please... (Juliet)
Juliet
From what I can tell you have a Flint plant (V) manufactured on Nov 6th (1106) 1973 350cid used on C-10 to 2500 trucks (TJZ)
3970010 is a pretty good block from what I understand
Hope that helps
The website I got this from is http://www.nastyz28.com/sbchevy/sblock.html#ecode
Take It Easy
Scott :D
Hope that helps
Take It Easy
Scott :D
Location: Your Fighting Tigers of LSU. 2003 National Champs
I concur, Juliet.
TJZ 73 truck motor, 175 horses, 4bbl. Probably has dog heads on it.
:seeya
:seeya
