Dunno why I didn't think of this before
Still trying to come up with the perfect air induction system.
had a good start with the remote air filter can and the throttle body plenum, but it made accessing the drivers side plugs 'n stuff a real pain.
Bought one of those Ram Air boxes in that takes a regular 14" by 3" AF,and then has a fiberglas surround to duct to a cold air source.
But, to make it work with the stock 1961 FI air inlet by the rad support was going to take some fiberglas work on the air box to make the 6" by 4" air inlet on the Ram Air box go to a smooth transition 4.5" round to connect ducting to.
i had a vision of what i needed to do to the ram Air box, but wasn't sure of the execution.
Then it hit me:
Go to the local craft store and buy a chunk of 6" by 12" by 12" open cell hard styrofoam, and shape it with a rasp to blend the 4.5" round duct feed into a nice smooth transition to the air box, then cover the styrofoam with plastic grocery bag material and start laying the fiberglas over the plastic covered foam core, then go in later with a screw driver and just break the styrofoam into powder and pull out the bag liner.
That styrofoam idea would have saved me a lot of work had I thought of it when I was doing body reconstruction, it is cheap, real easy to shape and would have worked as an excellent inner form piece for some of the body areas I had to rebuild. Just duct tape it in place from behind, after covering with plastic grocery bag material, and lay in the first layer of glas until it is hardened, then complete the glas build, and shape to conture.
Doug
Then it hit me:
Doug
I use high density foam (insulation board) to make all kinds of fiberglass pieces. If you need a really smooth surface, use body filler on top of the foam. If you want to save yourself a lot of sanding, you can have smooth surfaces on both sides by making a fiberglass "female" mold on top of that and creating your own "press molded" pieces.
Charles
Charles
Doug
Doug
Perhaps a transition piece could be made for you or a custom air cleaner to fit your situtation.
Chuck
