Calling a Desktop Dyno Operator ?? Requesting a run through !
Thanks my Forum members.....I know I am the black sheep in here but it's great to be part of a family !
Let me know what you need as
Engine
rebuilt stock not bored over
Type: Chevrolet ohv V-8
Bore x stroke, inches: 4.00 X 3.48
Displacement, inches: 350
Compression ratio: 10:1
Carburetion: Edel 750
flat top pistons
cam
Edelbrock RPM (hyd.) #6073
Adv. Duration: 308°/318°
Duration @ .050'': 234°/244°
Gross Lift: .325''/.340''
Lobe Seps. 112°
Duration at .006 Lift: Intake 308° Exhaust 318° Centerlines
Duration at .050 Lift: Intake 234° Exhaust 244° Lobe Separation: 112°
Lift at cam: Intake .325 Exhaust .340 Intake Centerline: 107°
Lift at valve: Intake .488 Exhaust .510
Timing at .050 lift: Open Close
Intake 10° BTDC 44° ABDC
Exhaust 59° BBDC 5° ATDC
Crane Blazer roller rockers 1.5
Cylinder head specifications
Edelbrock RPM
* 170cc Intake runner volume
* 60cc Exhaust runner volume
* 70cc Combustion chamber volume
* 2.02 in. intake valve diameter
* 1.60 in. exhaust valve diameter
* 1.45 in. valve spring diameter
* 3/8 in. diameter rocker arm studs
* 5/16 in. hardened pushrods are required.
Flow numbers
.100" Intake/Exhaust 72/61
.200" Intake/Exhaust 134/105
.300" Intake/Exhaust 188/140
.400" Intake/Exhaust 224/160
.500" Intake/Exhaust 233/172
.600" Intake/Exhaust 233/179
these don't matter but:
RPM air gap intake, gear driven, billet pulleys, alum. water pump,etc.
need more info ?? thanks in advance guys....
[Modified by ylose, 11:02 AM 11/16/2001]
Engine
flat top pistons
cam
Lobe Seps. 112°
Edelbrock RPM
Flow numbers
Re: Calling a Desktop Dyno Operator ?? Requesting a run through ! (ylose)
Desktop Dyno 2000 owners, I'm considering asking this for x-mas. Does this program allow for forced induction setups (turbos/ superchargers) ? Thanks. :)
Re: Calling a Desktop Dyno Operator ?? Requesting a run through ! (mikeo)
I'm on my laptop right now, so I can't copy the graph, but the peak numbers are:
338 HP @ 6000
336 lbft @ 4500
338 HP @ 6000
336 lbft @ 4500
Re: Calling a Desktop Dyno Operator ?? Requesting a run through ! (rainman69)
thanks rainman.....you always answer these posts....gotta give ya a high five for that.....my thanks...
one note.....if my compression is at 10.5:1 what would the difference be ?
gasket thickness are beautiful thing...
errr....did I ask too much here.....then just :smash: me down..
thanks again...
[Modified by ylose, 10:13 AM 11/16/2001]
thanks again...
I try...and besides, every time I do one, I learn a bit more about DD2000.
I just guessed that you had the cam installed 4* from the Lobe Centerline (108*), and if I knew that, I could be more accurate. Also, what is the exhaust system?
Rainman what did you use for exhaust ?
I got these results with small tube headers and mufflers:
360@6000 HP
342@5000 TQ
although I used the .488 in lift intake
. 510 in lift exhaust
from the performer RPM cam file.
360@6000 HP
342@5000 TQ
Re: Calling a Desktop Dyno Operator ?? Requesting a run through ! (-HIC-)
Also If you give me yer email address I can send over the files or teach me how to post the pics.
Bryan
wtih 10.5 compression I returned these numbers max HP 367@6000 and TQ 348@5000.
please double check you're cam specs , the lift looks a little low for the perf. RPM
Bryan
dynomax headers through true duals....manza mufflers...
thanks...
i got these specs from the web site....?? i think your right....where did i get those other ones.....ouch
[Modified by ylose, 10:25 AM 11/16/2001]
thanks...
A few variables were needed to complete, but I got the about the same results as Rainman. If I left the cam at 0 but used small tube headers with mufflers - 338 hp @ 6000 rpm , 358 lb/tq # 4500. I do not have the flow numbers of the Edelbrock RPM heads so I used the built-in flow of a Wedge with pocket porting.
I hope this helps.
I hope this helps.
Re: Calling a Desktop Dyno Operator ?? Requesting a run through ! (BlueShark29)
cool looks good ...
RPM flow numbers are on this page it that helps...
http://www.edelbrock.com/automotive/head_flowdata.html
great to see so many helpful members...
my numbers still come out to , with 10:1 compression
358 @6000 HP and 348@5000 TQ ,
Bryan
[Modified by -HIC-, 5:24 PM 11/16/2001]
Bryan
358 @6000 HP and 348@5000 TQ , Bryan
you have mail
"Gross Lift" as listed in the spec is defined as the lift of the lifter only.
The numbers you normally see, like .500 are "valve lift"
Thus, you have to multiply gross lift by the rocker ratio to get valve lift.
Therefore, the cam has a lift of .485/.510 (unless I'm crazy...somebody tell me if I am, please)
I used HP Manifolds and Mufflers. I will swap out to small tube, unless you know the exact diameter of the DynoMax headers.
thats good info rainman , so my holley sytemax cam with my 1.6 rockers actually has .522 lift. :D
So, here I am, again with different numbers. It took me a bit, because my wireless network card only works in certain parts of the building.
DD2000 comes up with:
395 HP @ 6000
385 TQ @ 4500
(This is with the updated information, corrected head flow, and all, 10:1).
[Modified by rainman69, 10:40 AM 11/16/2001]
395 HP @ 6000
385 TQ @ 4500
well this is more to the claims I have heard....if we got it right... :jester
w00t...I am a happy man...either way the numbers are all a helluva lot better than stock !!
:cheers:
thanks dude....If I could get the dyno pics sent I would be in your debt...paper is always a great backup to people accusing of :bs
thanks all !!!
:cheers:
thanks all !!!
If this works (crosse fingers):
(My laptop is sturdy, but not the fastest...) :smash:
