Pics of my 650 Hp SBC and Race Car
Im looking for the dyno sheets now. Ill scan and post when i have em. Believe it or not this race car C3 front uprights to mount 13.5" discs with 4 piston calipers from an Audi 2 litre touring car. Have pics of the brakes..can suppply if u want.
[Modified by xrated, 12:53 AM 11/15/2001]
[Modified by xrated, 12:55 AM 11/15/2001]
Re: Pics of my 650 Hp SBC and Race Car (xrated)
Now THOSE are what I call spark plug wires! :eek:
So what does that big scoop on the front do? I've always wondered that.
Re: Pics of my 650 Hp SBC and Race Car (Simon Alexander)
The radiators are mounted corvette style (angled) just behind the grille. The front air dam aids aerodynamics and flows air the rads. The air for the engine is supplied from the ducts just underneath the windscreen. The round holes in the front dam have tubes in them which flow into the discs. Air flows into the middle and out the edges of the rotor.
What do you wear for hearing protection?
The sound level in the cockpit must surely be 100+ decibels!
P.S. Post those brake pics.
Here are some crappy pics of the brakes. U can see the red corvette upright (sort of). Sorry about the quality. Next time i have to pull em off ill take much better fotos.
I've always liked old Fords especially Escorts. That is one sweet ride you got there... I'm staying tuned to see those dyno sheets!
Now that's cool. Who's fuel injection management system are you using? I bet that is a real hoot to drive. Also, what kind of fastener are you using to attach the a-arm to the spindle? Is it a tapered stud or a bushing and a bolt?
Re: Pics of my 650 Hp SBC and Race Car (Lt1er)
Finally a funtional wing!!!!! awesome ride that has to be a HOOT to drive....By the way I say a civic at lunch with that same rear wing ..(I SWEAR)
:eek: :eek: :eek: That's a little too close to an engine for me. Man, you must have some fun in that thing! :cool:
Re: Pics of my 650 Hp SBC and Race Car (Chris O')
Burner--> I use Motec fuel injection. Engine is dry sumped and it doesnt get revved to over 7500. This particular block pictured has siamese bores. In reference to your spindle question. I dont quite understand. Do u mean how do i join the upright to the A-arm? If thats what u mean then its with the use of rose joints.
