What is the best way to eliminate CARB loading??
Old 11-14-2001, 02:50 PM
Alwyn678
Alwyn678's Avatar
Default What is the best way to eliminate CARB loading??
My carb will "load" up after idling for a while..Is there any remedy for this??
Old 11-14-2001, 03:08 PM
Neo Fender
Neo Fender's Avatar
Default Re: What is the best way to eliminate CARB loading?? (Alwyn678)
Leave every traffic light at WOT.
Sorry I couldn't be of real help. :rolleyes:
Old 11-14-2001, 03:15 PM
The Dude
The Dude's Avatar
Don't know what kind of carb you have, but you may have a float level problem.
Old 11-14-2001, 03:22 PM
Alwyn678
Alwyn678's Avatar
Default Re: What is the best way to eliminate CARB loading?? (Jack Sweet)
It is a 600 edelbrockw/electric choke
Old 11-14-2001, 03:40 PM
norvalwilhelm
norvalwilhelm's Avatar
Loading has got to be caused by running too rich. Foat level can effect this, leaking internal, wrong or blown power valve or too rich an idle setting or circuit
Old 11-14-2001, 04:27 PM
SmokedTires
SmokedTires's Avatar
Cruise-In III Veteran
St. Jude Donor '05
Default Re: What is the best way to eliminate CARB loading?? (norvalwilhelm)
If you do a lot of starts in the garage/ driveway and run for a short time, you may want to try a hotter spark plug. :)
Old 11-14-2001, 04:30 PM
Alwyn678
Alwyn678's Avatar
Default Re: What is the best way to eliminate CARB loading?? (mikeo)
Ya know that is exactly what I do plus the plugs have not been changed in like a year or so......I amy try that as well as checking the carb over..though it is pretty much brand new
Old 11-14-2001, 06:11 PM
Hershey
Hershey's Avatar
Alwayn678, Check your float level and also your fuel pressure. Edelbrocks will flood on more than 6lbs of pressure. Hershey :chevy
Old 11-14-2001, 06:59 PM
AlwaysWave
AlwaysWave's Avatar
Default Re: What is the best way to eliminate CARB loading?? (Hershey)
Sure enough :) I had to add a fuel pressure regulator to mine. Took care of all the "rich" problems.
Old 11-15-2001, 03:12 AM
8T1-7T9 BIONIC VETTE
8T1-7T9 BIONIC VETTE's Avatar
Hershey,
I have Edelbrock 750. I plan to install regulator tomorrow....My engine is also running rich....The question I have for you is.....Screwing the Idle mixture screws in makes the mixture rich or lean?....Thanks in advance for your answer. Also what's the procedure for setting idle mixture?.....:seeya
Old 11-15-2001, 07:41 AM
Matt Gruber
Matt Gruber's Avatar
years ago (1990) i had everything tuned properly, but the plugs were black. got electronic ignition and plugs are clean and light tan.
Old 11-15-2001, 09:42 AM
Alwyn678
Alwyn678's Avatar
Default Re: What is the best way to eliminate CARB loading?? (drives61)
I will stay with points...I have already had some bad experiences with Pertronix products....But thanks for the idea!! :D
To What is the best way to eliminate CARB loading??
Quick Reply: What is the best way to eliminate CARB loading??
