rattlesnake-like sound from a C5
2000 C5 Coupe - 70,000 miles
Just started happening. When I turn the car on I hear what sounds like
this pinging sound or rattlesnake like sound coming from the front of the car. And it gets louder if I turn on the AC.
I popped the hood with the engine running and the sound appeared to be coming from around the serpentine belt area, so I replaced it because I recently found out it was cracking and was meaning to replace it anyway... But the sound still persists.
The sound has a higher frequency as I accelerate, and it's much more prominent when I'm driving next to a curb (sound bouncing off the curb) So is it coming from near the wheels?
The sound seems to go away if I have been driving for a while or if I come back to the car after it having been parked for a few hours. But when I leave it parked overnight, the sound is back strong in the morning.
I'd be grateful for any ideas.
Thanks!
Thanks!
First check to see if there is anything stuck in your fans.
If not, then trying starting the car without the accessories belt. If the noise stops it is one of your accessories.
If you said it gets worse with the A/C running, have you checked the A/C belt too?
It sounds to me like one of the idler pullies or the water pump. With the engine running, take a long screwdriver and touch it to the components in the belt system (fixed portions). It will amplify the noise when you find the source of the problem. The sound will resonate through the screwdriver and yous hould also be able to feel what's causing the noise.
Kinda the same noise under mild acceleration 99 6spd.
Yep, I;m investigating the same type of noise more like a scissors blades coming together.. will keep ya posted
Thanks![/QUOTE]
Thanks![/QUOTE]
Sadly, I just started getting the same noise. It starts about 1 minute after a cold start or after you let the car cool down for a few hours and then goes away after it gets hot or a few miles of driving. Its like a chirp chirp mixed with a hiss, scissors sound like it too.
My idler pully makes a squeek when it's cold. It does go away when it gets warm. If you want to find out if it is the idler pully, simply get a squirt bottle and set the squirt on 'Stream'. Start the car and pump a few squirts on the pully center. If the bearing is the problem, the water will slightly lubricate it and the sound will go away for a while. If the sound doesn't go away then it's something else in your serpentine belt area. Make sure your power steering fluid is at the correct level too.
Cheers
Did you ever find out the cause BTW?
-vvv
To summarize, folks on this forum have suggested it could be,
A/C belt
lifters
water pump
belt tensioner
idler pulley
harmonic balancer
With most folks leaning towards idler pulley probs.
As an aside - if I could only find a decent corvette mechanic in the Northern Virginia area. Dealerships are such a ripoff!
-vvv
i have the same exact problem the squeak of the belt when its cold. I only have 33k in the car. but its a 99 so i went ahead a replaced the serpentine belt anyway it had very minor cracks.
either way i ve noticed it now i don't remember noticing it before (ive only had the car 9 days).
its so annoying .
the noise does go away after couple mins but i know for sure i cant hear the noise at idle. Only at 1100-2500 rpm
its so annoying .
I can do general stuff but i haven't found a mechanic yet. Let me know if you do??
i heard of some guy name tony or tonys shop heard hes really good. not really sure on contact info
I too am very interested in what it turns out to be. Mine turned out to be the h2o pump. All sorts of of diagnostic listening lead me to give that a 50% prob. When I took the belt off the pulley was quite wobbly. With the belt on it tracked true. I took the frisbee off and now I wonder what sort of demons that move has uncorked, but that might be a subject for another thread.
