How does a Richmond 4 speed fit in a C3?
How does a Richmond 5 speed fit in a C3?
Oops, meant Richmond 5 speed... Is there a shifter available that will fit the stock C3 handle location? How about crossmember modifications? I came across a real good deal on this trans, but I'd like to know what I would be getting into. Thanks!
-Joe
[Modified by Flareside, 7:51 PM 11/12/2001]
-Joe
Re: How does a Richmond 5 speed fit in a C3? (Flareside)
I'm not sure about the Long Engineering shifter handle, but I believe there is something for the Hurst. For my Long shifter, I modified my old hurst comp+ handle by shortening it and bending it slightly back for the right feel. As for the actual shifer,both the long and Hurst will be in the right location.
The only mod for the crossmember involves a mod to the mount bracket that hangs off of the front of the crossmember. The manual that comes with the tranny has sketches of the needed mod. I'm sure one of us that have done this swap can scan a copy for you if you need it.
My car was origially an auto with removable crossmember. This made it much easier to get in. From what I have heard, you will need to remove tailshaft housing to get it in. Good luck
[Modified by tsw71, 5:13 PM 11/12/2001]
Re: How does a Richmond 5 speed fit in a C3? (tsw71)
Tom, it's funny you mention the Long shifter, because that's the shifter that comes with this trans. I didn't think it would fit in a C3. So my best bet would be to use an aftermarket handle and then bend it to fit?
Thanks!
-Joe
Thanks!
-Joe
You will have to change out a U joint, and a spline. The tailshaft takes a 26 tooth spline, same as TH 400, and a larger u joint. You can get the combo ujoint to fit the 26 tooth spline and your drive shaft at NAPA. Think part number is 323 or 324 or 325. Can't remember but they have it
Re: How does a Richmond 5 speed fit in a C3? (GDaina)
You must pull the engine and temporarily move it forward a few inches to get the tranny in. Richmond says to unbolt the tailshaft housing and it will go in with the engine in place, we couldn't do it after much effort. Much quicker and easier just to pull the engine from the start. Get the Long Engineering shifter along with handle HN-1085. You can use a B&M leather **** and it makes a nice setup. Don't know if the Hurst 5-speed shifter will accept the stock looking Corvette handle, but this tranny is a little higher effort shifting than most, so a comfortable shifter and handle is a must. The tranny mount needs to be modified so that basically the high point of the mount is cut back about 2 1/2 inches and this part of the mount is then welded to the back of the present part of the mount. The holes will need to elongated about 2 1/4 inches to the rear since the Richmond mounts are futher back than the Muncie/Warner. Set the shifter up on the tranny and get it shifting perfectly before installing in the car because you will have little room once it's in. The exhaust hanger will need to be turned around backwards. You will need a front yoke from a 68-70 with Turbo 400. The speedo cable will bolt up and the driveshaft remains stock. That's about it. It's a neat tranny that feels very
strong and precise. The Long shifter is also solid. The Richmond whines a little in the first 4 gears and although it is not as loud as the M22, it is noticeable while cruising at slow speeds with a mostly stock exhaust. Under accelaration the gear whine is very sweet and the closely spaced ratios steps are a lot of fun. You can also drop your rear axle ratio and really make the car more flexible. With the super low 3.28 first gear, you will have all the torque multiplication you need. I'm running the R-5 with a 2.73 axle and really like it.
Re: How does a Richmond 5 speed fit in a C3? (Allan71)
Great info Allan. Thanks! That's exactly what I needed to know. I'll let you guys know if I get the trans.
-Joe
-Joe
I've been following the posts on the Richmond 5&6 speeds,seems that most
who have installed them agree that it take more effort to shift then most
4 speeds.Is this just with the Long shifter or does the Richmond shift just
as hard with the Hurst shifter.One more question does the shifting get
easier as the Richmond gets some miles on it
Re: How does a Richmond 5 speed fit in a C3? (1RED1)
Tom
Gdaina, thanks for the tips. What axle are you running. I have a 3.55, but I doubt I could keep it.
-Joe
-Joe
Thanks for the info tsw71,what type of shifter and fluid are you using
Tom
Hey guys,
I was just jumping over from the C1&C2 forum and saw this post. I have a Richmond 5 in my '63. I am using the Hurst shifter. Due to the fact that the trans could not be lifted any higher in the tight midyear tunnel, the crossmember had to be notched to clear the shifter. Also part of the shifter mount bracket is cut away on the top. I was using a fake reverse lock-out shifter and it was unconfortable to shift. The lever is too short and the ball is to small. That's what she said. :lol: I switched to a short Hurst lever and ball. It is very comfortable. Shifting is much better; but very notchy. It is not that bad. I am using synthetic as recommended by Richmond for better shifting. I am using a 3:08 gear. For performance driving, it is ideal with my cam 219int./229exh. But a 2.73 is tempting for the interstate. Does anybody know where to get the gear new or already in a diff. ?
Other stuff to get after that 5 speed:
From Guldstrand
Ecklers was selling a 5 speed shift pattern plate a few years ago,
but I can't find a photo of that.
From Guldstrand
Re: How does a Richmond 5 speed fit in a C3? (71coupe)
I went to a local trophy shop with a drawing of the shift pattern. They made a nice plate that looks stock on the console.
Re: How does a Richmond 5 speed fit in a C3? (stngry63)
I called Ecklers - they stopped selling it a few years ago. Trophy shop, that's a good idea. Do you have a photo of it?
I don't have a picture of the plate pattern. It is made from plastic stock. The same kind that is used for office door name plates. It had a brushed aluminum surface. The pattern cut into it was the black color of the plastic underneath. They have several color combinations to choose. I would imagine that there would be something that would suit a C3 console.
I hope this info is of some help.
