What shock should I buy?
Hi All,
1980 L-82 with steel rear spring. What shock should I go for? However I would like to stay under $175 for the set.
Thanks in advance
Joe
Thanks in advance
Joe
Re: What shock should I buy? (Red73)
Rod,
All three of them are at Bairs right now for the works. I am staying with the 3.08's and using poly bushings in the front of the t-arm. I should have them all back by next weekend. Right know I am trying to get the crap off of the bottom of the car.
Joe
Joe
Re: What shock should I buy? (Xracer)
Xracer,
I think Bilsteins or KONIs will do the job!
They will improve the ride significantly.
You can adjust the KONIs, but I guess 95% of all buyers haven´t done this.
The Bilsteins are also great!
Its up to you!
Its up to you!
Cruise-In VI Veteran
Cruise-In VII Veteran
Delco Reactrac shocks are very close to original in feel, but a whole lot better performance. I think they are about $30.00 each, Zip advertises a set of 4 Delco shocks for under $100.00, but I'm not sure they are Reactrac shocks, they might be the cheaper Delco model.
Re: What shock should I buy? (Smokehouse69)
According to ZIP, Delco's Reactek shocks now sell under the name of "Performer". Zip told me they are the same.. just a different name. I ordered the Reactek when Zip offered the free shipping, and they sent me the Performers. We'll see when they go on!! :cheers: :seeya :seeya :seeya
Thanks everyone for the input. Since I need to stay under 175 for a set of four I am going to try the KYB's . Thanks again
Joe
Joe
