78-82 T-top adjustment instructions
Re: 78-82 T-top adjustment instructions (Rhys)
Thanks. I bought a used set off of a fellow forum member, and they came with new weatherstripping. I put the weatherstrip on , and now they fit really tight. The weatherstrip needs to be compressed for awhile I think. But, after they have sat for awhile, I will be finishing the adjustment, so it will be helpful then.
Platinum Supporting Dealership
Re: 78-82 T-top adjustment instructions (Dalannex)
Try using dielectric grease on the new weatherstrip. It softens them up.
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Ah, those are the same instructions that came with my new tops from Thompson Astro Tops.
By the way, I higly recommend their replacement t-tops with the plastic instead of the glass. They are half the weight and only $650 ish for new tops or $450 exchange.
If you have some of the really rare t-tops like the mirrored ones, I would buy a set of these for daily driving and leave the factory ones out of the sun (so they don't fade) and only use them for car shows and parades.
