Autocrossing & Roadracing Suspension Setup for Track Corvettes, Camber/Caster Adjustments, R-Compound Tires, Race Slicks, Tips on Driving Technique, Events, Results
***LG Motorsports World Challenge race cars available for purchase***
Old 09-12-2007, 12:04 AM
LG Motorsports
Premium Supporting Vendor
LG Motorsports's Avatar
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
Default ***LG Motorsports World Challenge race cars available for purchase***
Hi Guys,
Both of these cars are for sale immediately after the season finale.
$185,000 each complete race ready.
The #28 car was a two race winner with 3 poles. The Number 87 car sat on the pole at Sebring with Doug Peterson driving. The specs on the car are too numerous but I will mention a few.
LG Professionally built World Challenge Engine. 4 engines available at extra cost and at least 2 are sealed by SCCA as they were built. (we got tired of having to tear them down, but that only applied to LG wins )
Dailey Dry sump pumps and billet oil pans are standard on both cars along with the drive system that we have kept covered for 4 years now .
After you buy the car, we will give the buyer all the information on power and build sheet, with and without the 45% restrictor plate. The 45% restrictor plate takes away right at 50 hp, so if you don't run in the World Challenge series, you can add 40-50hp in 10 minutes.
Both cars have Holinger Sequential shifting, straight cut gear 6 speed transmissions with the SCCA mandated close ratios.
410 rear gears. Both the transmission and diffs are fully race preped with our own LG billet side covers and extra race work inside. The Holinger has its own internal pump and the diff has our LG single stage pump and billet Rear cover with pinion drive.
Spherical bearings in the Lower control arms, and our LG Motorsports designed chassis and suspension and sway bars. THere are too many things to list on the chassis.
Bosch 4.0 engine management with "No lift shift". That is correct, foot to the floor and pull back and the computer blips the engine for you so you never have to lift on an up shift.
This bosch 4.0 also has the same traction control as the ALMS Corvette and the Cadillac CTSv cars. We had to step up to the plate because without the high tech TC, we were at a slight disadvantage. But not any more. The Bosch ECU and TC is amazing.
Stack Data acquisition with predictive lap timer display. not only does it tell you what your lap time WAS, it tells you what it WILL BE before it happens. So you can see that a good lap is coming and keep the mistakes to a minimum.
Stop Tech 15" front and 13" rear brakes with Cobalt pads. This car stops so good it is scary. My face is now FLAT from hitting the windshield so much.
Tilton Triple Disc 5" Carbon Clutches on custom 5" flywheels.
LG Carbon Drive Shafts. Custom Torque TUbe. (if you buy it I will tell you what we did to them)
Wheels are Forgeline 18x10.5" front and 18x12" rear.
Both cars are built exactly the same but for the Driver's height. I am 5 foot 6 in and Doug (#87 car) is 6 foot 2 in. The brake pedal location is adjustable on both cars. The seats are in the same spot only the feet(pedals) move.
Bilstein/LG Coil over shocks with Race valving and spring rates.
Custom LG spec radiator, full Ram air (real ram air) with 14" water ram air pressure at 150 mph. Just to put it into perspective, a NASCAR Bush car sees about 7" of water pressure on the manometer at speed.
Full Ground effect body "wind tunnel tested" and a complete video from the GM wind tunnel will also be provided to the buyer with data.
The wings are from the LeMans Corvette C6.R but widened to meet the 72" wide width rule.
The car also has front under trays that were also pilfered from the design on the Le Mans C6.R Vettes.
You are not just buying parts that were put together, you are buying a fully tested and developed Corvette C6 race car that is so easy to drive fast, even I can do it.
This is probably the fastest Road race car on this forum. especially if you remove the restrictor and put some good tires on it. Seriously, it is bad to the bone.
You will get a full day of on track testing with you and your crew chief and me, Lou Gigliotti. ( I know that doesn't mean much to some of you pros but take it for what it is worth).
Neither car has ever been in a crash. A couple of tire circles and bumps but NO crashes.
These cars are not cheap. $185,000. as they sit. For the same spec car we could not build you one for less than $275,000. new, but we will if you want a brand new one.
If anyone really wants it after the Atlanta Petit Weekend, we can talk, but I would like to run the cars to the finish of the season.
I might consider selling the car without the Holinger, Bosch and Stack if there was a serious buyer at a reduced price (about $35k less).
Call me at LG Motorsports and let them know what you are calling for and they will give you my cell number if you are serious.
***Why are we selling? 08 Plans to be announced at Atlanta World Challenge race in 3 weeks. ****
These cars are collectors cars already. A piece of Corvette racing history. You can not pay too much but only too soon. Race it while it goes up in value.
Thanks and i will add some photos as I can.
Lou Gigliotti LGM
UTAH race, #28 and #87 finish 2nd and 3rd both on the podium
Charlotte on the banking.
__________________
LG Pro LT Headers, MOST HP, MOST TORQUE
http://lgmotorsports.com/gallery/alb...no_compare.jpg
LGM http://www.LGMotorsports.com
Winner Daytona 250
22 WC Wins
"Most powerful Corvette headers on the planet"
Old 09-12-2007, 12:42 AM
fatbillybob
fatbillybob's Avatar
Lou,
Will you take payments....just kidding
Old 09-12-2007, 12:50 AM
LG Motorsports
Here are some lap times, with Street Toyo DOT tires.
Put some Hoosiers or other slicks and drop another 2-4 seconds.
Results - GT
2007 Sebring Qualifying Results
_______________________________
Qualified 1st car # 87 Doug Peterson POLE POSITION
Bonita Springs/FL Chevrolet Corvette
LG Pro Long Tube Headers C6 2:07.679** 104.324
2nd #30 Curran 2:07.744 (This car was 100 pounds light per rule loophole for one race)
Qualified 3rd # 28 Lou Gigliotti Dallas/TX Chevrolet Corvette
LG Pro Long Tube Headers C6 2:08.598** 103.578
4th # 8 Andy Pilgrim Boca Raton/FL Cadillac CTS-V
XM/Mobil 1/Motorola/Bose 2:08.939** 103.304
5th # 1 Lawson Aschenbach W. Palm Beach/FL Cadillac CTS-V
XM/Mobil 1/Motorola/Bose 2:08.970** 103.279
Mid Ohio
Doug Peterson
3-Dimensional Services 1:26.759** 93.694
2 22 Randy Pobst Gainesville/GA Porsche 911 GT-3
K-PAX Racing LLC/Jim Haughey 1:27.237 93.180
3 28 Lou Gigliotti Dallas/TX Chevrolet Corvette
LG Pro Long Tube Headers 1:27.358 93.051
4 8 Andy Pilgrim
1:27.400 93.006
Watkins Glen
1 #22 Randy Pobst
Gainesville/GA Porsche 911 GT-3 K-PAX Racing LLC/Jim Haughey 1:55.167** 106.280
2 -#1 Lawson Aschenbach W. Palm Beach/FL Cadillac CTS-V 1:55.980** 105.535
3 #28 Lou Gigliotti Dallas/TX Corvette LG Pro Long Tubes 1:55.747** 105.747
Qualified at a 1: 54.xx
4 #8 Andy Pilgrim Boca Raton/FL Cadillac CTS-V 1:55.554** 105.924
Mosport--- (LGs first race with New Bosch 4.0)
#30 Eric Curran East Hampton/MA Chevrolet Corvette 1:22.972 106.691
# 1 Lawson Aschenbach W. Palm Beach/FL Cadillac CTS-V 1:22.975 106.687
# 28 Lou Gigliotti Dallas/TX Chevrolet Corvette LG Pro Long Tube Headers 1:23.087 106.543
4 8 Andy Pilgrim Boca Raton/FL Cadillac CTS-V 1:23.501 106.015
Old 09-12-2007, 02:11 AM
HORNDAWG
HORNDAWG's Avatar
L.P.
Old 09-12-2007, 08:52 AM
VetteDrmr
VetteDrmr's Avatar
Received 1,417 Likes on 759 Posts
Lou,
My keyboard is getting slick from all the drool; what a setup!! I feel like Charlie Brown after he gets a look from the red-haired girl of his dreams!
Gonna be an awesome ride for someone: good luck in selling them!
Mike
Old 09-12-2007, 09:37 AM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
I've always said if I won Powerball I'd buy a race car and go racing... too bad I didn't win
Old 09-12-2007, 12:04 PM
WMUCarGuy
2nd Gear
WMUCarGuy's Avatar
Could there be an ALMS announcement coming!?!
Old 09-13-2007, 05:00 PM
Steve49841
Steve49841's Avatar
PLEASE do ALMS GT2!
Old 09-14-2007, 01:35 AM
fhturner
fhturner's Avatar
LMAO...how bad *** would that be to show up at an HPDE w/ one of these screamers?! Scare the bejeezus out of all the Porsches that you were gobbling up...
Yeah, they must really be fast then... So, Lou, does your "dealership" offer test drives??? Look forward to seein' you at Road Atlanta. Good luck!
FT
Old 09-14-2007, 07:52 AM
73-84 IMSA Widebody
73-84 IMSA Widebody's Avatar
How about a trade.......Good luck Lou
David
Old 09-14-2007, 08:37 AM
JDIllon
JDIllon's Avatar
Is there a group buy price if we take 2 ????? LOL JD
Old 09-14-2007, 08:55 AM
varkwso
varkwso's Avatar
I am trying to figure out how to slip in a new set of R compounds past the CEO...I think she would notice if one of these showed up...I wish...
Old 09-14-2007, 12:26 PM
LG Motorsports
FT
Test drive for Atlanta race = $35,000.
See you there.
LG
Old 09-15-2007, 04:51 PM
Locke
Locke's Avatar
Looking at the cars at Sebring this year and now seeing the list of modifications just confirms what I've been thinking for a few years now; that SCCA has allowed too many mods to the cars and they are way too expensive to build and maintain.
It would appear that the series is geared toward manufacturer supported teams and/or teams with really big sponsorship. Maybe I'm way off base in my thinking and there are enough dollars and teams out there to support SCCA W/C GT, Grand Am GT and ALMS GT2 but it doesn't look like it to me.
It appears that SCCA intends the W/C to be for fully funded professional teams and expects there to be at least twenty of them ready to commit to a full season to make a promotable show.
The technical level of the series would seem to preclude the well funded privateer from having a car that could run three to five races a year in their region in a car that would be legal (much less competitive) for three to five years. To me that's the same recepie for success that killed the Trans Am when the rules left out the GT1 competitor.
Lou, good luck selling the cars and I'll be at Daytona or Sebring to cheer for you next year but before that happens go win the last two World Challenge races this year!
That would be sooo
Old 09-17-2007, 09:11 PM
LG Motorsports
Locke,
I agree. They allowed way toooooo much.
LG
Old 09-17-2007, 11:18 PM
codysdad
codysdad's Avatar
Default number #28 is too fricken awsome!
Sorry I'm just another guy with not enough money. My screensaver is your awsome poster picture. All I can do is play the loto and pray!
Old 09-18-2007, 09:09 AM
LG Motorsports
OR.....YOu can call Sun Trust Bank, Fl. who finances Race Cars (ask for the Motorsports finance department)
I would. Really.
LG
To ***LG Motorsports World Challenge race cars available for purchase***
Old 09-18-2007, 09:21 AM
bjm
bjm's Avatar
I would. Really.
LG
Hmmmmmmmmm! That is interesting, I did not know that!!!
Old 09-18-2007, 05:08 PM
V8 Juice
Support Corvetteforum!
V8 Juice's Avatar
That's our man JD, always looking out for us.
Old 09-18-2007, 08:19 PM
LG Motorsports
Yes, here is the group buy details.
You get a group of 10 guys, and put up $18,500 each and there you have it.
This would be a novel approach but with 10 races, you could all do one race in the World Challenge series.
It would be the most talked about topic in the Corvette world.
Thanks
Lou G
Quick Reply: ***LG Motorsports World Challenge race cars available for purchase***
