Front Air Dam
Old 08-15-2007, 11:02 AM
SatanicMechanic
SatanicMechanic's Avatar
Default Front Air Dam
Thinking of adding a front air dam, can anyone recommend a link or two to check out?
I really like the look of MagicV8's air dam picture in the cooling issue thread, not too prominent and seems a functional improvement. Maybe he can chime in...
Thanks!
Old 08-16-2007, 05:24 AM
67pete
Support Corvetteforum!
67pete's Avatar
Back in the day I used a '69 Z-28 spoiler on my '67.
Old 08-16-2007, 04:32 PM
lovevettes
lovevettes's Avatar
Default front air dam
If you mean a front spoiler, Ecklers sells one , Part number 10187, for 120 bucks, for a C-2.
tfos750 (07-18-2017)
Old 08-16-2007, 05:00 PM
Howy
Howy's Avatar
I don't know were this one comes from but here's a picture of mine.
Old 08-16-2007, 05:11 PM
SatanicMechanic
Ordered the Ecklers one, thanks!
Can't tell if it's the same one as the '63 above, looks great though!
Will update after delivery and installation.
Black or body color? Hmmm...
Old 08-16-2007, 05:42 PM
bweaver999
bweaver999's Avatar
Here is the Ecklers link:
http://www.ecklers.com/product.asp?p...7&dept_id=1353
Curious if you are doing it for looks or cooling?
Old 08-16-2007, 08:56 PM
Howy
Howy's Avatar
That one from eckler's looks like mine.
I put it on there to keep the front end on the road.
Howy
Old 08-16-2007, 11:14 PM
magicv8
magicv8's Avatar
Mike Snelling at Mid Valley Auto Body in East Moline Il has the mold that mine was made from (about $100) 309-755-1134
Improves mileage, keeps bugs off the suspension, helps the cooling system, and gave me a place to mount deer whistles.
I'd tell you it adds to high speed stability, but I've had it on the car for 16-17 years - way before Montana went without a speed limit and I went berserk on US-2 three summers in a row. I have never noticed a high speed handling problem, but I also run tail high - which some c2 high speed drivers claim also adds to high speed stability in c2s. I do it because I like the "look".
Old 08-17-2007, 10:13 AM
SatanicMechanic
Well, in theory I'm doing it for the front end high-speed handling. I haven't had a problem with such things YET, but eh, prevention beats cure right?
I don't have any cooling problems (knock on wood, knock on head), rarely goes above 180 even on hot days in a highway traffic jam.
And yeah, I do like the look, although I'm more after a subtle "touch", not a cheesy ground effect appearance. Keeping it black seems like it would make it stand out less, but I will deal with it when I see how it looks installed.
MagicV8, what I really like about yours is that it appears to NOT extend to the parking lights, instead just sort of fading away under the nose. I dig that. I'll see how the Ecklers piece looks with or without modifications, since it's already on it's way here. If I'm not happy with it, I'll probably give your damn dam molder guy a call and go from there, will keep ya posted.
Thanks all!
Old 08-18-2007, 06:33 PM
vstol
vstol's Avatar
Magic do you have another pic of the spoiler, it did not come out very well
Old 08-20-2007, 01:56 PM
macdarren
macdarren's Avatar
I've always liked magic's spoiler too...Maybe I will give that number a call.. I would like to see some other photos, maybe with the car on a lift to see a shot looking up. What I most want to know is how it is mounted. I don't want to make any modification to the car...want something that is 'bolt-on' and just as important 'bolt-off' should I want to remove it.
Magic, can you fill us in on the mounting for the spoiler?
Thanks
Darren
Old 08-20-2007, 02:11 PM
glenn64vette
glenn64vette's Avatar
I put the picuture in Paint Shop Pro and killed the contast, nice looking spoiler.
Old 08-20-2007, 05:38 PM
magicv8
magicv8's Avatar
This pic was actually taken to show off my homemade grille.
Old 08-20-2007, 08:06 PM
Crazyhorse
Crazyhorse's Avatar
I thought someone once posted a pic of that setup also, and
It looked simialr to magicv8's which I like too
Old 08-20-2007, 08:35 PM
macdarren
macdarren's Avatar
I really like the Grill, but I know it is not likely I will do that I know it is rather unique.... Also I like the relocation of the plate...I may just be able to put the front plate back on if I do that....what exactly did you do to lower it?
Magic can you tell us if the spoiler is just bolted on....looks almost like it could be held on with existing hardware, I know there are a couple bolts under the chin area (not sure that would be enough) and also a gap between the factory fiberglass and the radiator support which you might use as another hard point.
Old 08-21-2007, 07:14 PM
Howy
Howy's Avatar
Here's another angle outside.
[IMG][/IMG]
Old 08-21-2007, 07:37 PM
SatanicMechanic
Nice pic
Diggin' the look more and more.
It should get here tomorrow, antici.............................patio n persists. Hopefully the rain will not.
To Front Air Dam
Old 08-21-2007, 09:08 PM
macdarren
macdarren's Avatar
I look forward to seeing your results, and hearing about how the spoiler attaches. I am considering the Eckler unit as well. I will paint mine black and I wonder how it compares to MagicV8s....Keep us posted.
Old 08-21-2007, 09:11 PM
Sky65
Sky65's Avatar
St. Jude Donor '05, '09, '15
[IMG][/IMG]
I have been thinking about one of those myself. Do you have side view? Thanks.
Old 08-22-2007, 05:34 AM
Howy
Howy's Avatar
I will take the cover off the vette tonight and take a side view picture.I am leaving for work now so i will post tonight.
Howy
Quick Reply: Front Air Dam
