Door ajar replacement
After a bath this weekend the blue beauty decided that the driver door is ajar even when it isnt. Tried a few things to adjust it but thinking i just need a new switch. Is the switch something you can just unplug and replace or does the door panel have to come off?
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
You have to remove the entire door panel assembly on my '92. Easy from there, though. Plug-n-play. They run about $20 or less at most dealers.
A little worried about removing door panel, every other vehicle i have ever owner once the door panel is off never quite fits right again, rattles etc. Suggestions to make sure it is done right? Also, seems the PO drilled out the holes the switch (button) was in and now it has screws that are just too big, thinking that is part of the reason button doesnt depress all the way. Can this be fixed?
Before removing the door panel, the best advice I can give you is to remove the panel carefully and order the Screw & Nylon Insert Kit for door panels from Mid-America Motoworks (MAM).
The inserts tend to break when you uncrew them from age and fatigue and it's all too easy to loose those black, metal screws. It's $9.99 plus shipping.
http://www.mamotorworks.com/corvette?frame=1.967
Great advice, thanks cant seem to find a screw and nylon kit for a 96? Think they made one?
Is there a way to disable the door ajar light, interior lights etc until i can replace it? Makes it a pain to drive this way!
I replaced the door ajar switch on my 95 without removing the door panel. You have to be careful. Tighten the bottom screw just a bit to make sure it is tight. I then removed the top screw. You will need to have something (closehanger bent just right) to hold the plate on the back side/ inside of the door. There is a plate on the back side that will fall if your not just right with it.
Give it a try, if the plate falls just take the door panel off and do it that way.
You can bypass this switch, but you have to get to the connector inside the door. I'm not sure just disconnecting will make the lights go out, but I don't think it will.
Try this
Lower screw..replace with a longer screw started into retainer to hold retaining plate in place.
Remove upper screw.
Pull switch outward & rotate to expose upper screw hole.
Reinstall upper screw to hold retainer.
Remove lower screw.
Pull switch outward & depress harness lock tab to allow passage of switch & harness thru opening.
Switch from harness.
Install or connect.........
Switch to harness.
Switch & harness into door.
Long screw thru switch & lower door screw hole into retainer.
Remove upper screw.
Rotate switch & install upper screw thru switch into retainer..
Remove lower screw & replacw with original.
Switch will adjust the first time you close the door.. Be firm, but donot slam!!!!!!!!!!!!!!!!!!!!!!!
Remove upper screw.
Remove lower screw.
Switch to harness.
Remove upper screw.
Cool Hand Luke of W MI
I think teh first time I did mine on my 92 the inside of the plug fell back into the door panel so i ended up having to take teh panel off. It went back together just fine.
Good luck!
Good luck!
I think if you pull the COURTESY fuse in your fuse box (located on passenger side of dash) it will disable the door ajar switches.
Still, your technique sounds good and I will try it next time I have to replace my door ajar switch. Thanks!
