89 L98 6Speed Targa $4500
Im listing my baby because she just does not wanna stop giving me problems.
shes has 128k on original motor
i have 2 sets of wheels which are the original 89s (one of the rims is busted up so really a set of 3 good ones)
and a full nice set of 90s wheels
right now its currently having ignition problems and not wanting to start after a few startups .. also has a misfire on 1 and 3 im pretty sure... it drivea but with loss to power..
i have replaced everything on the dist except the ooil....
i have reasoned most likely to weak spark and bad fuel...
she has 2 minor body flaws and one major from the accident it was in.. someone backed out of a driveway without looking and hit me in the front right tire and ripped a small hand size chunk out of the hood and bent the rim (its repairable)
i had a new fuel pump installed, new battery as of last week, New alternator end of last year before i put it up and it has true dual exhaust running from precats back straight with Magnaflow muffs on it... she sounds purrty
6 speed ZF tranny in great condition and has a newer 6-7k miles clutch (previous owner told me Spec 2)
rear end is mint not a problem there at all... stock gears never been touched
im asking $3500 obo... located in Michigan... come pick it up .. trailer it home .. make a beast out of it.! Jim
FYI, you may have a blown head gasket, between cylinders 1 & 3. I've an 86 and had 4 (weak) and 6 not firing. I replaced the head gasket - it had a space the width of little finger nail between 4 & 6. A mechanic diagnosed it as follows, get 4 or 6 to TDC and push air into the spark plug hole. On my car, air was going in 4 (TDC) but coming out 6 spark plug hole. You might try it with 1 & 3 to see if you have that problem. Jim
[QUOTE=89vettefromhell;1561344874]
As I read the post, I immediately thought "coil".....then I got to this (above).....you've done this much, why not change the coil for a new one? Sounds like its getting heat soaked and not giving you enough voltage after its hot.
wish i could edit my topic to include the price drop to $3500!!!!!!
come on 89 L98 6 Speed ZF coupe!!! someone does not want to come get this STEAL! project car or rebuild.. this is a great start for ANYTHING!!!!!!
TTT
TTT
No one wants a AWESOME PROJECT CAR FOR CHEAP!!! $3500 trailer it home!!!! its still in good shape and has 2 sets of rims!!!!!! WHAT ARE YOU WAITING FOR BUY MY VETTE AND BUILD YOUR DREAM! (and mine) lol
ttt
ttt
lots of serious inquiries... no bites yet.. lets get this ball rolling... im going to the LOWEST i will possibly go... this is dead bottom i will not move from this
$3000
that is the bottom dollar.. come pick it up trailer home and make this a MONSTER!!!
$3000
