02 ZO6 Lingenfelter 427
Well, while Ebay gets their stuff together and fixes my account, here are the specs on my car:
02 Red with Black interior ZO6. 11,100 miles. 2nd owner
@4,000 miles car sent to 21st Century Muscle cars in Texas for conversion. 21st Century is the only authorized LPE installer
Over $100,000 invested
All records, all maint performed on time
Professional Pilot owned
LPE 427 C5-R block 550 hp, 530 ft lbs
3 quart electric engine oil Accusump with manual switch in cockpit
Ron Davis aluminum Radiator with integrated engine oil cooler
Breathless Performance intake and Vortex carbon fiber power duct
Random Tech 3" Stainless Stee; exhaust with Randon Tech hi-flow cats
Stainless Works 3" catback exhaust with LPE installed custom tips
RPM Transmissions Level V transmission
McLeod street twin-disc clutch with M.I.B.A. discs and aluminum flywheel
Dynotech Engineering Stage II differential and differential brace
JRZ double adjustable coilover shocks with remote shock cannisters.
Eibach springs
Vette Brakes & Products graphite impregnated polyurethane suspension bushings
Vette Brakes & Products (Moog) tie-rod ends
Brembo 14" in front, 13.1" in back. Brembo calipers with full-floating rotors
Brembo stainless brake lines
Doug Rippie Motorsports Front brake cooling ducts
HRE 541R forged aluminum wheels 18x10" front, 18x12" rear Polished with center caps
Michelin Pilot Sports with lots of tread left. 275/35-18front, 335/30-18 rear
Lingenfelter "Mini-tub" to accomodate wider wheels and tires
Doug Rippie Motorsports heat extractor hood
Doug Rippie Motorsports Tranny and Diff oil coolers with electric pumps. Coolers installed in rear brake ducts, with manual switch in cockpit
All hoses and fittings are Aeroquip woth braided stainless Steel hose and fire resistant shielding where needed
Hurst shifter
Caravaggio Custom Seats leather with suede inserts with custom Lingenfelter 427 embroidery and red stiching
Shift light
Speedware Motorsports Harness bar with fire extinguisher
Custom cargo compartment hole covers with OEM carpeting
Custom cargo partition
the list goes on...and on...
PM if seriously interested
Eibach springs
Hurst shifter
Shift light
as per forum rules, you need a price!
those hp/tq numbers you stated, are those wheel or crank? i would assume wheel, b/c my 427 C5R is making those number thru an A4. any drag times?
hell of a car though, good luck selling!
Aj
Aj
Would this be Mike Sullivan's former car?
If so it is a quality piece I had the pleasure of riding in one time. I tried to talk him into the TT version but this car has all the best parts and does everything well.
Pat
Pat
