•• New Released iForged TPMS Adapters (FITS MANY AFTERMARKET WHEELS) • $90 Shipped •
IFORGED PERFORMANCE ALLOYS RELEASES NEW TIRE PRESSURE MONITORING SYSTEM SENSOR MOUNTING SOLUTIONS
•• FITS ALL IFORGED WHEELS & MANY OTHER AFTERMARKET WHEELS ••
•• $90 Shipped (COMPLETE PACKAGE) ••
iForged Performance Alloys releases two new innovative tire pressure monitoring system sensor mounting solution options for all iForged wheels and many other aftermarket wheels. The tire pressure sensor mounting solution is backward compatible on all iForged wheels and many other aftermarket wheels. The National Highway Traffic Safety Administration has announced that all passenger cars beginning with 2006 model year must be equipped with tire pressure monitoring systems. By creating a new tire pressure mounting solution, it will enable you to retain their factory TPMS capability with no error codes when using aftermarket wheels.
*Please contact us if you are interested in purchasing or have any further questions. Thank You.*
Regards,
Kenneth
TheModCity
iForged TPMS 90 degree sensor adapter
iForged TPMS 90 degree sensor adapter installed
iForged TPMS straight adapter installed on wheel
iForged TPMS straight sensor adapter
iForged TPMS straight sensor adapter installed
iForged TPMS straight sensor adapter installed on wheel
iForged TPMS straight sensor adapter installed on wheel [inside view]
I have these on my new Iforged 3 piece wheels and they made mounting the sensors a piece of cake. These replace the hidden valves you have on your wheels currently. This "new valve" has a hole in it inside the wheel that the sensors fasten through. The complete sensor sits inside the wheel. Works great.
Former Vendor
I hate to assume, but you mean the 90 degree ones correct ?? I think the design is ingenious !
Call John or Chip at CCW to verify that.
Bob
Thanks.
If you need a tool to do the relearn procedure I can help you out (from $150 to $220).
Your best bet for new sensors is from forum vendors Fichtner or Gene Culley (go to Gene's website at: http://gmpartshouse.com ). On Gene's site you'll see:
||--Genuine GM Tire Pressure Sensors--||
25758220 – Tire pressure sensor – 49.13 each
15234846 – Tire pressure sensor nut – 3.16 each
Total setup is 209.16
That's about as good as you'll do with a set of new sensors and nuts.
Bob
to THEMODCITY
I have true forged speed 6 wheel, i think here is a link that the guys here gave me.
http://trueforgedwheels.com/images/Wheels/Wheel5lg.jpg
I need a 90degree stem to hold my tpms that is 3 inches long. Do you have them?
thanks
John
thanks
John
