Problems downshifting after new motor install....driving me bonkers
All,
I installed a new motor back in January. I moved my relatively new LS7 clutch (maybe 12K on it...slave on the car had same amount of miles) to the new motor. At that time the clutch was working great. During the motor swap I didn't touch the hydraulics, torque tube, shifter or the tranny.
Now for some unknown reasons I'm having issues mainly downshifting from 4th to 2nd. Example: exit freeway in 4th, push clutch in, slow down to normal 2nd gear speed, try to put in gear to turn at a light or whatever and its as if its gated or something....it won't go into gear for a second or two. Typically I feel a relatively low frequency vibration coming up through the shifter but its nothing like a gear chatter that occurs when popping out of gear. It feels like something not engaging properly but not a high frequency gear grind. Additionally, I have some up shifting notchyness that I don't think was their before the swap either.
I've bled the clutch and adjusted the shifter a million times with no luck. Re-checked the pressure plate bolts...still tight. I find it hard to believe it would be the tranny as I didn't touch it. My instinct is that the clutch isn't disengaging properly. Anyone have any thoughts? I haven't replaced the master but I may try that.
I would also say the clutch is the problem. How far do you let the clutch out before it starts to grab? If it's just barely off the floor then that's the problem
Received 8,958 Likes
It sounds like your synchronizers are going.
Bill
Bill
It seems to engage maybe 2-3" off the floor. I'm considering mod'ing my master to adjustable to see if that might solve my problem.
Hate to dig up a thread this old BUT I am hoping OP is still around maybe say what fixed this issue? (I did a search and this thread was the closest to what I am experiencing)
I did have the engine out a couple of times now, I bought the car with a bad engine and never drove it before removing engine.
My shifter is Tight and slow as best way too explain it, I can get all gears when I want up and down, But I cant say I could really drive it in anger as the shifting action is so slow and tight.
I haven't tried anything as of yet to try to correct the issue.
