Old 03-06-2015, 05:49 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: General How-Tos
Print Wikipost
$9 DIY Aux input for Ipod for C6's with XM
Old 07-03-2007, 10:39 PM
Gearhead65
Gearhead65's Avatar
Default $9 DIY Aux input for Ipod for C6's with XM
Here's a DIY for adding an Auxillary input to a C6 with XM. First, thanks to Ray for his information in this post and help in figuring out the wiring on the XM!!!
http://forums.corvetteforum.com/show...t=c6+aux+input
First, go buy one of these at your local Radio Shack.
Then, pull your XM module out of the back. You'll need to cut back some of the black wire wrap around the harness coming to the unit.
I also found someone on another Corvette forum that posted a diagram from an 2005 C6 Digital Receiver. It appears to be the same for my 07.
Cut off the female end of the radio shack extension cord (I cut around 10 feet off) and strip back the wiring. Connections should be made as follows:
Red - Green/White (Right Audio)
White - Brown/White (Left Audio)
Bare - Tan/White (Common)
I first tried to connect these without disconnecting the three (3) wires from the XM harness. I could only get a humm and no audio. So, since I don't subscribe to XM, I cut these wire a couple inches from the harness and hooked them directly to the extension cord. (Don't forget to insulate the bare leads with tape or or a blind crimp connector.) This worked perfectly. Just switch to the XM band and turn on your iPod (or whatever device you have it plugged into)
It was a 5 minute job to run the extension cord under the carpeting and up under the side of the console to the cup holder area.
If you do subscribe to XM, you will need to install and 3PDT switch to switch between XM and Aux input. So far, I don't see away around this if you use the XM, but other may have suggestions. I'm not an XM fan, thus not concerned about it.
Thanks again Ray (Kawal) for the inspiration and help.
Enjoy!
Davtc (04-14-2023)
Old 07-03-2007, 11:42 PM
JBVette
JBVette's Avatar
Thanks for the post. What's your feedback on the sound quality?
cobraspence (04-17-2017)
Old 07-03-2007, 11:53 PM
dknight129
dknight129's Avatar
St. Jude Donor '07
I bought a scosche ipod interphase system from CarToys, plan to install it in the morning. I'll let you know how it goes. does the radio have any rca jacks on the back?
seadog2u (08-07-2018)
Old 07-04-2007, 01:07 AM
autophile
autophile's Avatar
Fantastic post! Since I'm not an XM user, this shouldn't interefere with anything correct? Even better! Thanks for the info!
Old 07-04-2007, 01:41 AM
tiggerrick
tiggerrick's Avatar
Enjoy!
What's a 3PDT switch, and how would you install it?
Old 07-04-2007, 01:50 AM
humvet
Support Corvetteforum!
humvet's Avatar
Very
Old 07-04-2007, 01:57 AM
bocabob
bocabob's Avatar
i'll just go to cartoys here and have them do it.. ouch
Old 07-04-2007, 03:18 AM
Atomic-Vette
Atomic-Vette's Avatar
3PDT = "Triple Pole, Double Throw". it's basically like having 3 toggle switches that are controlled by one "toggle" so you would hook up the L, R, and Common from the XM unit to the center pole, the L, R, and Common from the Harness to one of the outside poles, and the L, R, and Common for the i-Pod to the other outside pole. This way when you flip the toggle to one position it enables i-pod and disables xm, then you flip it the other way and vise-versa.
Old 07-04-2007, 03:25 AM
SunsetOrangeCreations
SunsetOrangeCreations's Avatar
Location: Exhaust Commander Wireless Bi-Mode Exhaust Controllers, Innovative and advanced technology! --- Check out our website @ www.sunsetorangecreations.com
St. Jude Donor '13
I think your close but not quite.
On the 3pdt switch ususally the center pins are the common out of the switch. And that would go to the wires leading to the head unit. Then the pins from one side of the switch to the XM unit and the pins from the other side to the IPOD jack. That way when you flip the switch it changes from the xm signal going to the center common out, to the IPOD jack going to the common out.
Always look at the switch as they can be made differently, but the common out goes to the head unit and the separate inputs go the the two devices that are comming in..
Hope that clears it up.
Old 07-04-2007, 03:36 AM
Atomic-Vette
yeah that's it.. I got my typing backward :P
Old 07-04-2007, 03:42 AM
shopdog
shopdog's Avatar
Also, couldnt you just perform this same mod where the wires go into the Head Unit instead of running wires from the back to the front and then back(in the case of an XM user)?
You could, but it is a heck of a lot easier to get to the wiring at the XM module than it is to get to the wiring in back of the radio.
Old 07-04-2007, 08:24 AM
Gearhead65
Gearhead65's Avatar
In my opinion, it's great. I've had direct connect of the iPod in other vehicles and it is as good (or better in some cases) than that. I set the iPod level to near max and that gives a similar output level to the other bands (CD, FM, AM) so the stereo volume doesn't need to be adjusted between bands. It cranks!!!
Old 07-05-2007, 11:29 PM
pentavolvo
pentavolvo's Avatar
Cruise-In IX Veteran
i thought this was common knowledge ive done this on a few C6s and it works out great no issues at all, i actually use this cable though http://sonicelectronix.com/item_6794...s+NC-iRCA.html so i can get lineout from the ipod and charging capabilities... i have noticed that its not quite as loud though as a normal cd
Old 07-06-2007, 12:06 AM
Vitamin_J
Vitamin_J's Avatar
Great posts for the archives for sure! Now someone who is much smarter than me figure out how to make this work with the NAV system.
Old 07-10-2007, 02:58 PM
scott_fx
scott_fx's Avatar
Enjoy!
it would be better to use a 3pdt relay and run a single wire to a toggle switch up front. another option is to use david navone's AUTO TRIGGER CIRCUIT. N-902 (instead of the toggle switch) and hook it up to the ipod's output. When you play music through the ipod it will switch to that source automatically. when your ipod is off it'll default to xm
Old 07-10-2007, 03:32 PM
TheKomoman
TheKomoman's Avatar
St Jude Donor '13
It will work with the NAV system as an AUX input the same way it will for non-NAV. You may be asking about controlling the iPod from the screen.. which would require programming and accessing the serial data bus. Not really a DIY mod!
Thanks for the info Gearhead, very useful!
Old 07-24-2007, 07:29 AM
SilverSurferC6
SilverSurferC6's Avatar
I went with the USA-SPEC PA11Vette and while the overall result is acceptable, I find that the output volume of the XM module is not. I called my dealer and complained about this and was told that this is due to the units not matching up and they currently do not have a solution. I literally need to crank up the volume when in XM source to get decent sound out of the XM or my iPod now.
Controlling the iPod through the Nav is cool though.
To $9 DIY Aux input for Ipod for C6's with XM
Old 07-24-2007, 03:29 PM
SilverSurferC6
Default Really pizzed about low output of XM mudule
Anyone out there as ticked as I am? The volume is so low! Has anyone been able to get a DIY fix or get GM to fess up and fix it?
JohnnieUtah (08-09-2019)
Old 07-26-2007, 08:02 AM
ChuckTu
ChuckTu's Avatar
This is something I've been looking for forever...went ahead and did this for my Sirius radio and it works awesome...thanks for the idea and great pictures!
Old 08-07-2007, 07:52 AM
C6 Corvette - SRQ
C6 Corvette - SRQ's Avatar
The Auto Trigger Circuit (relay) sounds like the best option to me. I believe in the Keep It Simple Stupid principle... Plug & Play?
Has anyone used this when connecting an iPod? How difficult is it to do? Do you need to tap into a 12-volt source to power the relay?
Thanks!
Ed
Quick Reply: $9 DIY Aux input for Ipod for C6's with XM
