Just tried the PC (pics)
I got the PC yesterday and just did one test area to see how it works.First off I have never used any kind of buffing machine before so this was my very first time.I used a orange pad with Menerza IP and did 2 passes.....
This is before buffing
This is after buffing
Former Vendor
nice work ... remember the Vettes clear is quite hard, so several passes and a steady hand are needed. Nice difference, and dont be afraid to use some speed as the PC transfer very little heat (unlike the rotary).
Former Vendor
Yeah Zaino Fusion or 106ff, something like that. Zaino Fusion is very very good and a pleasure to use.
The reason is that the Orange pad may leave some micromarring (that you might not even see) but can give the paint a slight haze(that you may not notice until comparing next to a side that doesn't have the haze). Using a ultra fine polish w/ a softer pad will burnish the paint, remove the micro scouring and give you a brillant finish.
You are doing an amazing job, BTW!!!!!
I sure will...Thanks again.....Where in South FL ?
I just tried the white pad with some Zaino Fusion.....After I was done why were there swirl marks? I then used Menerza IP and they were gone....Confused
