2008 C6 LS-3 First Dyno at LG Motorsports
#41
#42
you can have a car go to two different shops, dyno near exact numbers, and then have the graph lines appear quite different, even though every plot point might be essentially identical. Shop A might use one set of x/y increments, shop b might use a different. Look at graph A and go "wow....thats really flat tq", then view graph B and say "wow, very peaky". graphs are great, but the raw data points are better so you don't get "trapped" by "optical illusions".
#43
Very interested in seeing the MN6 results. But comparing this sheet to mine with headers/intake/tune. I'm way ahead in TQ/HP. By 3Krpms I'm already at 350tq. Pretty much confirms my thought that if an LS2 owner wants stock LS3 power they only need to add a couple bolt-ons
It's difficult to compare numbers otherwise (and LG Motorsports are known for having a more "conservative"/realistic dyno calibration than many shops use for after mod readings).
EDIT: I know you have used Cartek in the past and they are very well respected, also.
#44
thats a good question. I've never owned an automatic car, only manauls, but from personal experience with my '02 z06, and using the exact same dyno facility (MTI houston, tx), I believe my initial dyno at 700 mile was around 351/350 SAE. Made an oil change after, drove the car pretty hard with many 1/4 mile runs, redynoed at 2700 miles and made like 357/353.
so maybe 3-7 range is pretty common after break in
#45
Sorry if I was not clear. What I am asking is if LGM ran the same dyno on the same car, but with a broke-in motor, under similar conditions, what would the estimated change be in tq/hp. Just curious what to expect from a dyno from motor that is broken in vs. 29 miles.
#46
#48
On man I can't wait. This is exactly what I was predicting. Close to 400 whp for the new 2008's
Already 370 whp for the auto. Woot come on M6!!!
#53
#55
#57
Is 384rwhp still considered 'close' to 400?
Of course if this thing puts down 397rwhp in stock trim (not going to happen) than I too would agree that it is VERY close to 400.
