[Z06] Halltech Killer Bee hose routing update
Premium Supporting Vendor
Here is something you guys may want to try when setting up your Killer Bee. For my car, I oriented the throttle body coupler with the hose barb in the 7 o'clock position (when looking into the throttle body). I cut the ends off the vacuum hose to the dry sump tank and routed a rubber hose along the radiator and heater hoses. I think this looks a little cleaner than the plastic line on the top of the intake, ESPECIALLY for customers who have the painted intake and valve cover combo. Cutting the ends off the hose is very difficult and you have to be careful not cut yourself. It is also very difficult to push the hose onto the line ends, but with a lot of force it can be done.
Supporting Vendor
St. Jude Donor '09
Very sweet indeed. Clean and mean.
We're going to have to start sending instructions for that fix.
Jim
Supporting Vendor
St. Jude Donor '09
Jason, did you use 3/8" rubber hose? Can you give us the length? Pretty slick.
We've bee cutting 1.5" off the end that hooks up to the PCV nipple and heating the plastic tube with a heat gun and forcing the PCV into the hose line. It looks completely stock and fixes the problem as well.
The biggest problem is the time and shipping costs to send the new line for the customers exchange.
Yours is a much nicer and cleaner way to do it. Maybe you could send a few more pictures and we'll set up some instructions.
Thanks!!!
Jim
Thanks!!!
Jim
Thanks!!!
Jim
Thanks!!!
Jim
Yes, 3/8. I'll measure the length asap.
Supporting Vendor
St. Jude Donor '09
I'll have a supplemental instruction set on my website tomorrow.
Supporting Vendor
St. Jude Donor '09
http://www.corvetteLS7.com/Instructi...stallation.doc
This was done quick and dirty, and somewhat incomplete, but it should help get the job done. 48" piece of 3/8" rubber hose does the trick.
First off, this is a very clean set up, kudo's to Jason.
Second, would this be the line that one would install a catch can to keep the intake void of any oil residue if your driving hard in the mountains or at the track?
Third, do you think that a catch can is needed on the C6Z to keep the intake clean?
I installed a catch can on my C5Z and had no more problems with an oily intake.
What about the factory hoses?
Dear Jim and Katech:
Do you guys know where to get the factory hose, fittings and tools to work with or make factory looking lines? Are they silicon, pvc, etc.? What about those fittings too? Any info would be appreciated. Also, what about installing one of those venting canisters on the lines. What do you guys think?
Thanks.
VetteRobbie
Thanks.
VetteRobbie
2. Yes, but see #3
3. The dry sump tank actually works like a catch can itself. I don't think anybody is having excessive oil in the intake after track events. All the intakes I have removed have had a normal amount of oil film on the floor but probably not enough to have a significant amount of oil consumption. Maybe Short-Throw could post his oil consumption with his many miles of hard track driving.
Thanks.
VetteRobbie
Thanks.
VetteRobbie
