388 LT4 Goes BOOM at 8000 RPM !!! Warning to all....
Hydrolock at 8000 rpm. Motor has siezed.
Warning to all : if you see slight amounts of smoke coming from your exhaust, please take the time to verify if it is coolant or oil.
Long story short. Motor was not broken in correctly. Without a wideband the car was running well rich when first built. probably washed out the rings/walls whatever because we saw complete glazing of the walls when we were fixing pan leaks.
So, motor did burn slight amounts of oil, and would smoke when revved unless it was fully at warm temp. My guess is the forged pistons would seal up better when expanded.
Our mistake was confusing the slight smoke over the last few weeks for oil. it was ever so slight, some days non existant.
Over the last few weeks I;ve been chasing a wideband wacky reading where it would steady out and then jump all over the place. no doubt now I know it was due to one cyinder burning slight amounts of coolant.
Few nights ago I was out datalogging on a beautiful night with a friend in a 2002 r1. yes I did kill him in every roll on race On the way home I stomped on it one last time in first gear.... Puff of smoke, slight jerk.. service engine light on and low coolant light on... hit the clutch in and rolled to the side of the highway.
Motor siezed. No fluid leaks, underhood clean. Blowing white smoke out the left exhaust confirmed my guess of a head gasket (not 100% confirmed I guess). had her towed home. Mechanically she ran perfect until it happened. 8100 rpms all night long and not a whimper.
Last but not least by the time i got a flatbed 6 hrs later on the side of the road it was daylight and I can see small metal bits in the exhaust
on the bright side, A new block is being prepped already. new LS1 firing order custom camshaft with more lift (going from 578/588 to over .600... not sure how much over .600yet ) I'm just hoping my titanium valves and rods are not destroyed. I'm also glad this didn't happen in 4th gear at 8000 rpm.
make me feel better guys.
Received 3,043 Likes
St. Jude Donor '05
Damn, tough break! What size cam are you running to wring 8k out of yoour stroker?
You might want to invest $25 in a Lisle #75550
Combustion Leak Detector kit When you get the
engine back together. It is a quick and easy
method of testing for gasket leaks and cracks.
exotic rotating package down below.
Displacement
3.75" Stroke for 388 ci with 4.060" bore
Piston Speed
5000 FPM for 3.75" Stroke at 8000 RPM
5000 FPM? That engine must have some kind of3.75" Stroke for 388 ci with 4.060" bore
Piston Speed
Displacement
Piston Speed
Piston Speed
Lol i don't need to rev it to make power. I wanted it to. I asked the builder to build me somethng that is smooth idleing, daily driveable but will spin to 8k. He built me exactly what I asked for. to hear my car go through the bay st. tunnel at 7500 rpm in 1st gear was worth it alone. I just wish I made more sound clips
To be honest the motor isn't that serious at all. It makes good power and I was happy with it, nothing insane. I'm not into the 1/4 mile so I atually reduced the rear gears to 3.73s from 4.09s I had in it before the build. The cam is a solid roller of course, <.600 lift 230 + duration with a 115 LSA. Most of the $$ went into the heads, and using the lightest possible components for the rotating assembly/valvetrain.
I think, from my best guess is perhaps the cylinder wall has collapsed into the water jackets. That's what might have led to the hydrolock condition. We did bore the block .060 over so that may have thinned the walls a bit ? My guess is that the leak was gradual and only got worse from the cold air that was making more cylinder pressure etc and it finally allowed some coolant in. When compressed there's only 3 places for it to go.. out the head, through the piston of through the walls. I'm not familiar with hydrolocking conditions etc so I'm just guessing. When we pull it apart we'll know the extent of the damage.
With regards to the shoppe I know this is a touchy situation so I'm just hoping all goes well and we can work this out and both parties come out happy. I'm also hoping to have it back together asap or I'll be buying a brand new R1 and the car can sit for the year
Large Impressive Member
Location: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
He already stated that it was.
well the motor was designed and built to rev that high. It was the only reason that almost every part in the motor was specifically chosen. There has been numerous small issues related to sloppy jobs done on the car that we have been correcting over the last year. Even the wiring to the electric water pump wasn't the greatest job that I had to repair after a few times the temperature would get real hot (perhaps the real cause of a head gasket starting to leak?).
I can only imagine the damage that could have been done had this happened in 4th gear at high rpm. the force of the car at that speed would probably have detroyed most of the motor when it tried to lock up. this happened in 1st gear at a slow speed spinning its tires somewhat and she shut off instantly and I had the clutch in asap. Time will tell.
and quite possibly the car and you included!!!
I know the two engines can't be compared (your 400+hp to my 190, and much less than half the engine size), but the overall effect was still rather dramatic.
race engines have no warranty.ask me how i know
i would hope anyone who would bore an engine .060 would sonic check it for cylinder wall thickness.especially one that would turn that kind of rpm.
i would also hope it had main and head studs.yours may have,it was just a thought as i was reading.
Perhaps it did, but the resulting piston speed at 7700 was
well under what Pryderei's 388 sees at 8K
increase of the shaft speed.
For reference purposes, the new generation LS7 has a stroke of
101.6mm (4.00") and a redline of 7,000 - this results in piston speeds
of 4,666 FPM. The LT4 in the 1996 GS has a stroke of 3.48" and a
redline of 6,300 - good for 3,654 FPM.
At 8000-8100 RPM, Pryderei is in rare air. Another post has a list
of 28 engines and their piston speeds. The S2000 tops the list at
4965, still a bit under what Pryderei's 388 has been spun to.
Displacement
91mm Stroke for 2157cc VTEC H22A4 with 87mm bore
Piston Speed
4598 FPM for 91mm Stroke at 7700 RPM
Reciprocating inertia forces increase at the square of the91mm Stroke for 2157cc VTEC H22A4 with 87mm bore
Piston Speed
8000 ??
