Drive vs Driven Gears
I have noticed alot of guys on the forum switching out their posi's which I did some time ago (4:11 to 3:08). No doubt now that their speedometer readings are affected. I have been to those websites that have formulas for figuring out which driven gear goes with which drive gear but most say you need to know which drive gear you have before determining which driven gear you need.....everyone still with me Ok, so the question is....how do you tell? Unless you pull the tranny and then the tailshaft is there another way to figure it out? Did early BW T-10's only have one drive gear for example 8 teeth? All I know now is that anything above 60 mph the speedo reads 45 . I have tried a few different driven gears (more teeth/less teeth) and haven't found the right combo yet. This is driving me nuts...any advise on what to try next would really be appreciated.....Mike
You should be able to see the drive gear teeth thru the speedo cable hole in the tail shaft. Mark one of the teeth and count the number of teeth there are on one revolution of the tail shaft. Just like counting the teeth on a differental ring gear.
vetrod62
vetrod62
Received 3,772 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Most, but not all, trannys have the 8 tooth drive gear on the mainshaft inside the tail housing. There were also 2 sizes of drive gears: 1.76in and 1.84in diameter. The driven gears were, and still are, available in 17-25 teeth from GM. Within these 10 different gears, there are also 2 sizes. The smaller size (17-22 teeth) is used with the larger 1.84 drive gear and the larger size (22-25 teeth) is used with the 1.76 drive gear. If you use a large driven gear with the large drive (1.84) gear, the large driven gear will eventually get chewed up. If you use a small driven gear with small (1.76) drive gear, it will either very minimally engage or not engage at all. If I were going to roll the dice, I'd bet that there is a much greater chance that your tranny has the larger 1.84 drive gear (most trannys did have the larger one). Therefore, the corrosponding driven gears that will work in your tranny are the smaller, 17-22 teeth gears. ALLLLLLLLLLLLLLLLLLLLLLLLL the driven gears are color coded and the large and small 22 teeth driven gears are also different colors (the big one is green and the small one is gray, sometimes called silver).
GENERALLY speaking, a change in one tooth (up or down) of the driven gear will result in about a 5mph change in the speedo. Also, GENERALLY speaking, for each change in rear gear ratio, such as going from 4.11 to 3.70 or to 3.55 or to 3.36, etc, will require changing the driven gear by one tooth. Thus, if your car had a 4.11 rear gear and you switched it to a 3.08, then you would have changed the rear by 4 ratios, and probably a change to 4 FEWER teeth of the driven gear would get you in the ball park, if not right on the money. So, if your driven gear had 22 teeth with a 4.11, then a change to an 18 teeth driven gear should get you close.
Hope this helps.
Hope this helps.
theodude (11-13-2018)
Received 1,857 Likes
The 1.76" dia. DRIVE gear (3708145) is .531" wide, and the 1.84" dia. DRIVE gear (3708144) is .610" wide (both are 8 teeth); you can check the width through the speedo adapter opening with a cardboard gage.
Hope this helps.
Hope this helps.
Yes, adding teeth on the DRIVEN gear will reduce the speedo reading (cable runs slower); a one-tooth change results in about a 5% change in the reading.
OR you can pull them up on gmpartsdirect.com
SMALL GEARS
3987917-17 teeth-purple (still good)
3987918-18 teeth-brown (still good)
3987919-19 teeth-natural (still good)
3987920-20 teeth-blue (still good)
3987921-21 teeth-red (still good)
3987922-22 teeth-gray (or silver) (still good)
BIG GEARS
3860345-22 teeth-green (still good)
3860346-23 teeth-black (still good)
3860347-24 teeth-yellow (still good)
3860348-25 teeth-orange (still good)
OK, OK, I went ahead and did your work for your.
OK, here are the GM part numbers/colors/teeth. I'll post them and YOU call your friendly neighborhood GM parts dept to check to see if the numbers are still good.
SMALL GEARS
BIG GEARS
SMALL GEARS
BIG GEARS
GMPartsDirect.com did not recognize the part numbers for the driven gears. However, I found RiversideGear.com which seems to stock the correct stuff with their own part numbers. Their speedo gear catalogue is labelled "muncie-4-speed/speedometer-gears-drive-and-driven".
Hope these are the same for other GM transmissions; my new driven gear is going into a TH-400 in a '67 GTO.
OK, I just went to gmpartsdirect and ordered 5 different gears by the part numbers that I posted (I like to keep at least 2 of each gear in stock at all times, 3 of some gears). The order was processed just fine and I was given a confirmation number.
This morning I pulled the driven gear and counted the teeth....22 and it's brown so I'm not sure how it got in there but I'll bet bubba knows. Couldn't really see what drive gear I had since the tranny brace was in place. As suggested, I will try an 18 tooth........thanks for everyones inputs.....Mike
