548 Big Block. Dynoed at 777 HP. NA
For Sale: New 548 Big Block. Dynoed at 777 HP. NA
REDUCED $8500!!! My friend has a New 548 he built for his car. It is fresh and was dyno tuned. Not run since. Have Dyno sheets. Best of everything. Carb to pan. Am compiling a list of parts. I know he wants $10,500 and has much more in it. Built and dyno tuned by Performance Motorsports.
Engine Info!
Here is the info. This IS a street engine. This has Dyno time only on it. Freshly Pro Built, Dyno Tuned 548 Big Block W/ Bowtie Standard deck Race block. 4.530 bore.(can go to 4.600) 4 bolt mains, Steel splayed caps, Fully ARP studded. O-ringed, Copper head gaskets. Set up to run a 300 shot of nitrous. Kieth Wilson ported 454R intake, port matched to heads, Chuck Nutten 1150 dominator. MSD HEI, Dart 308 Fully race ported heads. Crane Roller rockers, SS valves, Comp Cams Solid roller billet cam .722 lift, 276 int duration, .722 lift, 284 Ex dur, 110 LSA 108 ICL. Speed pro forged 10.25 to 1 pistons, Lunati Pro Mod Rods, BRC 4340 forged nitrated Crank, High volume oil pump, Moroso valve covers and 7 Qt oil pan. SFI Balancer, Steel flexplate, Dyno runs on 91 octane gas 778 HP @ 7000 rpm, 680 ft lbs @ 5000. Will post dyno sheets as soon as I can scan them. over 700 HP from 5500 to end of run @ 7200. Over 600 ft ls from 4300 to 6700. He built this to put in a 65 chevelle street rod and sold the car as a roller. Just imagine this with a 300 shot on it!
Received 1,900 Likes
2017 C2 of Year Finalist
Looks like a sweet setup......interesting that he used iron heads...and then had them ported? Any flow numbers on them? They must be doing well to hang in that good at 7K!
As many folks are building these things out there...it ought to be a good sale. I'll let folks know about it!
JIM
JIM
JIM
JIM
Hey guys, This is a Fresh, New 778 HP Big block that runs on 91 octane pump gas. The carb and intake arel over $3000. Has MSD Ignition. Drop it in, put a water pump on it, hook it up and drive it. It's ready to rock.
A 572 720R crate engine puts out 720 HP and is a race fuel only engine. List price $18856.00 (I have seen them for under $14,000) This 548 motor uses a standard deck height to work with stock configuration headers, has 60 more HP, runs on pump gas and is considerably less $. Someone has to have a project for this!
Thanks for the vote of confidence Eddie! Think this is going to have to go to E-bay. Hate to do it, I really wanted to see this in a forum member's car.
] Not even close! I got that in my 383 build. The 572 720 HP crate engine is $18,000 list and runs on 93 octane. This motor is NEW! has 58 more HP, runs on 91 and is a standard deck height. no header or steering fitment issues. Bolt it in and go...................Really fast!
Moderator Emeritus
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
