FS VBP Adjustable Rear Spring
FS VBP Adjustable rear spring. Sold the car I was using it on. This spring is $619.00 from VBP. Asking $400.00 plus shipping....OBO. Spring is in excellent shape and works very well.
Spring
Besides the item shown in the pictures, what else was required to install this item in your car? How much, if any, did it change the ride of your corvette?
Nothing else is needed to bolt on the car. It bolts where the stock spring would, and also those 2 stand-offs pictured clamp to the bat wing. You then use the same end links that you have. You adjust the stiffness by using the different holes in the frame. It will take you from a stock setting to a rock hard setting buy using the 6 different holes.
