[Z06] Brembos on.. 6 pistons fit behind stock wheels..
Just put on my new brake package. 14" Brembos, 6 piston front, 4 piston rear. I ordered the slotted discs, but Brembo is out of stock for now. These babies will pull you out of the seatbelts when you hit them. I have two new sets of wheels ordered for the track but I didn't think the fronts would fit behind the stock rims but they do. I put a 1/8 spacer just for a little more room. They are really close to the inner rim.
Thanks to John Page(21st Century Muscle Cars) for the hook up on the brakes!
SW
SW
SW,
You are in for a real treat. I've been running Brembos for the last 10,000 miles mostly on the track. I'm running the 4 POTS up front and I stand on these things all day long. The modulation is second to none!
Best of all you can change the pads in minutes!
Mike
Mike
Mike, I have been running Brembos on my C5 track cars for a long time also, they are really great. I went to a track day about a month ago with my C5. I broke a timing chain on Sat. I trailered it back home on Sat, and drove my Ferrari up on Sunday and ran two hard sessions with it and drove home. The 550 is a heavy pig but the factory Brembos with stock pads held up with no issues at all. As you know, they are worth the money.
SW
Brembo changed their GT kit from last year. They used 14" rotors to fit, avoiding going to 19" wheels up front. I thus went with 4-piston, same rotor, also drilled. They discontinued the slotted/drilled combo, my favorite. But, it's brick wall braking from he!!, I cannot imagine any more stopping potential. You'll less brake dust, seems ridiculous, but true.
Don't worry about the drilled rotors, unless you prefer another appearance. I've used drilled (GT set) on several cars for the past 10 track years, and recently closely inspected all of them, with all I hear about fracture lines, etc. Not a hint of problems. Wear is also even, never had to replace a rotor. Best upgrade ever. Congrads.
First - those things are drop dead gorgeous!!!! Question: I have the 4 piston brembos on my C5 and they perform flawlessly. Do the 6 piston brakes provide a significant improvement over the 4 piston version? How much extra $$$ do the 6 pistons cost over the 4 piston versions?
Thanks Kelp.
the 4 piston set up on my C5 track car..
SW
I was deciding on 6-piston also. Talk to Mike Brembo. If you are repeatedly braking from excessively speeds, you need 6 piston. I've never faded at any event. But 6-piston is better, more $$ too. Also look at overall pad surface area.
You've probably heard my example, but here again: I barrel down the front straight at VIR 130-150. I lighten up at 5 to coast to 120 and brake at 5? (no) 4? (no) 3? (no) (pause - as the instructor gets ready for a bowel movement) TWO - Bang! stand on the Brembos at 120, slow to enter the U-turn one.
I don't know how I could sink into the corner any further. And....I might run out of leather conditioner!
We see a lot of 360s and 430s by us. We had a 430 lose it's brakes last year. Luckily there was no damage. I was surprised. Even with the top brake brands, you have to watch pad depth for overheating.
Approx. 1$K
MTI Racing has those on their C6Z. They will repeatedly do 160+ to 50 going into Turn 10 at Road Atlanta with no protest. They are amazing.
That reminds me, I need to post up some videos from in that car.
That isn't actually too bad. My 4 piston set-up has never let me down. No fade ever enters the picture. I have the same set-up as SW in his pic above. I think I have a pic or two myself - I'll post them up. I must say though, those 6 piston fronts do look fine!
Keep in mind there is a limited choice of pads with the 6-POTS versus the 4. Reminiscent of the 19" versus 18" tire selection out there!
Former Vendor
But your man Mark at Fall-Line, from whom I just ordered a 6 pot set up, said that Pagid and PFC, amongst others, are gearing up to producing pads in the 6 pot size now.
The good thing about Brembo is that every pad manufacturer knows it is worth their while tooling up to make pads for whatever caliper they produce as they will sell thousands of units.
In the meantime, my set are going to ship with Brembo's street pad. Is that going to fade terribly on track? Mark seemed (wisely) to think they were a safer bet than Brembo's track pad in case they don't work well on the street, which would be worse.
Now you tell me!
The Pagid Orange is a great pad but not as aggressive as the Hawk Black. You will have more choices soon. Funny thing is I never ran the stock Brembo pads either. Pulled them out from day one!
Forum Member GoTreo put the 6-POTS on his black car and like SW here, they really do look great!
Mike
