C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] New TR-6060 Transmission for 08 Z06
Old 05-08-2007, 10:32 PM
dgdoc
Support Corvetteforum!
dgdoc's Avatar
Default New TR-6060 Transmission for 08 Z06
Sounds terrific.
Wonder what this might be worth in E.T. with our best drivers flogging it.
Could be time for an upgrade.
Old 05-08-2007, 10:42 PM
mcm
mcm's Avatar
What does a TR-6060 cost?
Old 05-08-2007, 10:51 PM
KILR-RYD
KILR-RYD's Avatar
So this is coming from the GM
would this be in the 08 C6 as well?
Old 05-08-2007, 11:38 PM
dgdoc
dgdoc's Avatar
Yes - I found this on the C6 board.
Pictures captured at a GM event/briefing.
Old 05-08-2007, 11:45 PM
vetteship
vetteship's Avatar
I hope this will eliminate the vibration and put a stop to the shift **** rattle
Old 05-09-2007, 12:28 AM
dgussin1
dgussin1's Avatar
tr6060 is in my car...it's a good trans. a lot less notchy than the t56 in my 04.
Old 05-09-2007, 07:36 AM
AU N EGL
AU N EGL's Avatar
grear ratios ?
Old 05-09-2007, 09:32 AM
BrokerDon
BrokerDon's Avatar
Default What car is the tr6060 trans in
What car is your tr6060 trans in now? I thought it was a new transmission?
I've got an '06 Z06 with the soon-to-be "old" T56 trans and it makes the "coffee can full of marbles" noise in 1st gear at low rpm clutch engagement... Just like all the other T56 Z06s I've heard.
Old 05-09-2007, 09:40 AM
urslooow
urslooow's Avatar
I get a lot of clicks w/ clutch half in, like when in reverse. WTF is that about
Old 05-09-2007, 09:44 AM
AU N EGL
AU N EGL's Avatar
well no offecne, dont drive with the clutch "HALF IN".
Old 05-09-2007, 10:42 AM
DJ'sZ
DJ'sZ's Avatar
From my understanding this new tranny is in the GT500 Shelby's...Drove a buddies Shelby and yes it's very smooth, precise and not as notchy. How it will take the abuse we can throw at it we'll just have to wait and see...
Old 05-09-2007, 12:48 PM
TeddyFreddy
TeddyFreddy's Avatar
That noise won't go away in the 2008 Z06 with the TR-6060. The noise is due to the engine-to-transmission tunnel. The vibrations of our beloved big engine are well... big. It makes that noise in any gear when torturing the engine (too small rpm, too much load, not enough gas).
Just give it progressive clutch with more gas! Drive it, not baby it!
Old 05-09-2007, 05:18 PM
urslooow
urslooow's Avatar
I don't do that except in reverse to control the speed going in Reverse out of my twisty driveway. Also happens during the first 1 or 2 transitions from clutch in to first in the AM. BTW that answer wasn't very cute nor helpful
Old 05-09-2007, 06:11 PM
outnumbered
outnumbered's Avatar
Steve, you may want to be care riding any clutch like that to control vehicle speed. It can certainly shorten your clutch life and possibly put hot spots on your flywheel which can cause chatter.
Dan
Old 05-09-2007, 06:20 PM
urslooow
urslooow's Avatar
Dan
Just talking about 1 second when going from rev to first, don't really "ride it" at all, just going easy on it.
Old 05-09-2007, 06:22 PM
dgussin1
dgussin1's Avatar
07 GT500.
Old 05-09-2007, 07:01 PM
dgdoc
dgdoc's Avatar
Here is a review of the TR-6060 from Mustang Magazine:
So you might be wondering exactly how a Tremec TR-6060 compares with the T56 you know and love. In short, it’s better in just about every way. It can handle more torque thanks to a move from a 10-spline input shaft to a 26-spline unit. Moreover, the new case is stronger, the countershafts are one-piece units, and the gear faces are wider. All these changes add up to much greater strength, which we’ll all appreciate after we start modding these cars. What we noticed while driving the car, however, was its easy, precise shifting despite the factory shifter.
The prime movers in the better shifting are increased synchronizers on all the gears. Where the Terminator T56 had only two synchros on the 1-2 and 3-4 shifts and single synchros on the remaining gears, the TR-6060 offers triple synchros on the 1-2 and 3-4, and dual synchros on all remaining gears, including Reverse. Plus, the synchronizers have been upgraded from a carbon-particle paper to a sintered-bronze material.
Gt500 Transmission Gears
A larger input shaft, beefier gears, more synchronizers, closer gear ratios, and more make this six-speed one that should become a popular aftermarket upgrade.
So this transmission shifts easier, but it also offers a shorter shift throw. “The synchronizer hubs are much narrower, reducing fore and aft shift travel,” Tremec’s Jim Averill explained. “Additionally, the hub system uses three encapsulated ball-and-coil-spring struts that are much more precise than the old-style hoop-and-stamped strut. This also adds to a smoother fore, aft shift.”
So the TR-6060 is smoother, stronger, and just better than its predecessors. That’s cool, but the better news for those who aren’t buying GT 500s is that Tremec will be rolling a lot of this technology into its aftermarket transmissions, so you’ll be able to put all the good stuff in your Mustang soon.
To New TR-6060 Transmission for 08 Z06
Old 05-09-2007, 11:35 PM
outnumbered
There was a time that the cutting edge tranny would be in the Corvette first. Now it's in a Mustang first?
Old 05-10-2007, 01:22 AM
mcm
mcm's Avatar
Timing, gotta do QA some time.
Can anyone answer how much these trannies cost and would there be issues (with linkages, diff & input mating) swapping one out of an 05-07 car?
Old 05-10-2007, 02:17 AM
EFE Z06
EFE Z06's Avatar
Here is a link to read more on the new trans!
http://wheeltalk.fancal.net/?p=841
EFE Z06
Quick Reply: [Z06] New TR-6060 Transmission for 08 Z06
