radiator stop leak
Old 05-01-2007, 12:29 AM
NINETNINEVETT
NINETNINEVETT's Avatar
Default radiator stop leak
I have a small leak in my radiator and wonder if anybody has used bars stop leak. Does it work. What are the draw backs to worry about. 327/365 motor
Old 05-01-2007, 01:29 AM
bweaver999
bweaver999's Avatar
Even if it stops the leak, I would not use it on a Vette. That's the stuff you try on an old beater that you want to try to keep running another year or so before the junk yard. If it really does stop the leak, it could seal things inside the engine as well that should not be clogged.
Better to keep an eye on it and add coolant as necessary until you can get the radiator repaired or replaced.
Old 05-01-2007, 01:36 AM
KENS78SILVERANNIV
KENS78SILVERANNIV's Avatar
Most people don't know how to use it correctly. They insist on dumping the whole container in the radiator. All that does it clog it up.
If you have a minor leak... where coolant is dripping very slowly... or just seeping... the stuff works miracles.
If you know how to use it.... and that means sparingly.
I'm talking about a small dash of the stuff... a bottle cap full. That's it.
It'll work.... check it out.
I've had it in my radiator 5 years.... stopped the leak in 15 minutes. Hasn't failed since.
Old 05-01-2007, 02:08 AM
devildog
Support Corvetteforum!
devildog's Avatar
Location: fighter pilots make movies, bomber pilots make history
Use it. A couple of years ago when I was freshening-up the engine in my 61, I thought I would give the radiator a good cleaning. I did and it had multiple leaks. It is the original aluminum radiator.
I used a bottle of the aluminum Bars. It plugged the multiple little leaks and have run it ever since. It will hold pressure over several days.
Joe
The original Bars is basically just wood fibers in suspension that plugs the small holes. The key is flush the excess Bars after the leak is plugged.
Old 05-01-2007, 02:16 AM
AZDoug
AZDoug's Avatar
Received 1,478 Likes on 905 Posts
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
For small seep leaks.
Condensed milk.
I think that is what it is called, the real thick, gooey sweet stuff, or maybe it is evaporated milk, but I think it is condensed milk.
It will NOT clog anything, but as the stuff seeps out and the water and glycol evaporates, it leaves behind a solid but pliable plug.
Doug
Old 05-01-2007, 02:34 AM
jtranger
jtranger's Avatar
If it is a small hole it can be sealed with JB Weld.
Old 05-01-2007, 02:41 AM
Ironcross
Ironcross's Avatar
Solder Seal makes a product called "Block Sealer" Thats the best there is. I sold both products [Barrs Leak] and the Block Sealer is better.
Old 05-01-2007, 08:39 AM
GCD1962
GCD1962's Avatar
Joe
It's not wood fibers. It's fiber from ginger root
Old 05-01-2007, 09:06 AM
crw41
crw41's Avatar
Bards stop leak was actually put in new engines at the factory.
If used per directions - it works fine.
Old 05-01-2007, 12:58 PM
JohnZ
JohnZ's Avatar
Received 1,857 Likes on 1,100 Posts
Bar's is STILL installed in all new cars and trucks at the factory, to seal against tiny seepage leaks at hose connections; every vehicle gets two Bar's pellets at the radiator fill operation. My plant guys called them "rabbit turds".
Old 05-01-2007, 02:02 PM
bweaver999
bweaver999's Avatar
Interesting, it's actually used in new cars!!!!! So is it a good idea to put a bit in when changing coolant components? Sounds like if it's good enough for the factory to have used for years it might be a good thing to do.
Old 05-01-2007, 02:52 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
if it's not leaking, don't fix it.....
Bill
Old 05-01-2007, 03:48 PM
avideo
avideo's Avatar
Default I Have Used Barr's Stop Leak In My 1995 C4 Coupe...
and it worked great. In fact, Richard Newton, who wrote a GREAT BOOK on C4 repairs recommends it in certain types of situations. I had a small but persistent leak of several drops of cooling system fluid that dropped on my garage floor after virtually every trip in my C4. I finally put in a really small amount - about 1 oz. in my system - and the leak stopped two years ago and has not returned. And as mentioned above, this product is used in new cars as well as being a factory authorized "fix" for cooling system leaks in certain models of Cadillac and Cherolet.
Old 05-01-2007, 10:00 PM
NINETNINEVETT
I tried it tonight. Put in about 2 oz. ran it for about half and hour seems to work no leak. We will see what happens. Thanks for all the tips. Mike
Old 05-02-2007, 12:20 PM
MikeM
MikeM's Avatar
Received 1,843 Likes on 1,398 Posts
You guys musta' been city slickers. They're too big for rabbits. We called the "dog turds".
Old 05-02-2007, 03:16 PM
Biggus Blockus
Biggus Blockus's Avatar
Did you use the Aluminum version or the Classic (turds in a jar)?
I've used both with good results in the past.
Old 05-02-2007, 03:42 PM
Road machine
Road machine's Avatar
Condensed milk.
Doug
Just so you know... Condensed milk is what caramel is made of. Just take a can of it and throw it in boiling water for a 1/2 hour and you have a can of caramel. Just think how your engine will love that gooey caramel after the first time it gets hot.
Just to be clear... this is a very bad idea if you were serious.
Old 05-02-2007, 03:43 PM
GCD1962
GCD1962's Avatar
The pellets in the liquid form are small, like rabbitt turds. The large pellets are sold dry in a plastic sleeve, I'd hardly call them dog turds, still too small !
Old 05-03-2007, 02:52 AM
NINETNINEVETT
Used the classic version. put a few oz and leak is gone so far. Will run it this weekend and see if it holds.
To radiator stop leak
Quick Reply: radiator stop leak
