Fan Clutch
Fan Clutch
I just received my new fan clutch. I was told it was an Eaton. I don't see anywhere on it where it says Eaton. Is this a Chinese knock-off? I paid a little over $100.00 for it so I want to make sure I didn't get scr-wed. Anybody have an Eaton and can give me some numbers or info?
Thanks
Thanks
Thanks
Thanks
Received 1,859 Likes
Thanks
Thanks
No GM or Delco box. Came from Florida. Here is their Ebay ad:
http://cgi.ebay.com/ebaymotors/60-61...4871QQtcZphoto
Ken
what does the front of that fan look like? Does it have a round or rectangle temp spring
Mr D
Mr D
Location: Park City to SoCal - according to the map it's all down hill. No bad days in Indian Wells, California
If you are not satisfied you be the final judge..... make sure you get what you paid for, what you were expecting and then maybe, just maybe if there's a probelm I'll have my Jersey boys go get him.
Jersey boys, now you're talkin. I really don't care if it's Eaton or not as long as it works. Just pisses me off the guy advertises with the Eaton brand name.
That's a Schwitzer clutch - both the Eaton design (coil thermo) and Schwitzer design (flat bar thermo) were used interchangeably, depending on what was on hand in the plant at the time; they were different part numbers, but were calibrated and released for the same applications. The Schwitzer clutches were date-stamped on the O.D. of the flange where they bolt to the water pump hub.
Tom,
I won't know until I get my car back from MSI. They are installing a rebuilt 370 rear end, Hurst shifter kit, factory clutch, and checking alignment/suspension. So it is sitting on my shelf until I get my car back.
Ken
Ken
