90 Track Car
90 Track Car
Here's whats on the car:
Suspension:
Z51 springs
Fx 3 revalved shocks (Morocco valving)
Poly bushings
32mm Front, 26mm rear, bars
J55 brakes with Carbotech xp 12 Front xp10 rear pads
cooling ducts to front brakes
Engine:
Ported and Siamese plenum
SLP runners
Accel base
52 mm TB
Cut lid with K&N filter
air pump eliminator
Turn One steering pump
Under driven pulleys
TPIS oil cooler with thermostat
TPIS coated long tube headers
3" dual exhaust with Dynomax mufflers
ZF 6 Trans. with B&M shifter
Fidanza Alum. flywheel
Carolina clutch stage 4
Kirk Racing rollbar installed have rest of cage not installed
Sparco suede steering wheel with LTB motorsports release
2 sets of 90 wheels one set with hardly used GSC's
other set no tires
2 sets of 91 sawblades one set with V710's 8 heat cycles
other set with unknown cycled Victoracer's
Have all parts removed from car except for plenum, TB and main cat.
Will not sell parts separate so please dont ask.
69K miles
Asking $9,700.00
Cell- 252-469-5616
Home- 252-641-1086
Suspension:
Z51 springs
Poly bushings
Engine:
SLP runners
Accel base
52 mm TB
air pump eliminator
other set no tires
69K miles
Asking $9,700.00
Cell- 252-469-5616
Home- 252-641-1086
Hello,
How do you like the Kirk roll bar? How come the full roll cage was not installed? Does not full roll cage have good fit? Could you describe where the roll bar/cage contacts the chassis?
Thanks,
Darrin
Thanks,
Darrin
The rollbar is welded to the rear frame rails.It sets on 3" x 3" pads about 3/16" thick. I never got around to installing the rest of the cage but the fit seemed good, although you do have to cut into the armrests.
John
John
sami85L98, I have all the original parts to the car except the plenum the TB and the main cat. The plenum is siamised, the TB was traded for a 52 mm and the main cat was gutted but I still have it. There are no cats on the car now it has long tubes and 3" dual exhaust. The engine is stock internally. Thanks, John
