[Z06] Harness Bar Mounting?
Those who use a harness bar on the C6Z06, what kind did you use and how did it mount?
Unlike the C5, the C6Z06 mounts are hidden under a plastic cover that can't just be "popped" off like the C5 with the actual piller plastic cover intact.
It seems you have to take the whole thing apart...not something I am happy with on a $70k car.
I am looking at the hardbar, does anyone have any pics of what it looks like?
Experiences? Do you have to cut the plastic cover or just drive around with it removed?
I use a Shark Bar, which was the first to become available. B-K has theirs out now (very expensive) and so does Hardbar. I had to take off the trim panels, cut a 2" hole in each one and then put them back. No biggy - you can to the install yourself if you work slowly and carefully. There is one pesky connection near the rear speakers that requires extra care - I broke one taking off a panel, but a little epoxy and it was as good as new.
Cruise-In III Veteran
St. Jude Donor '06-'07-'08
- Remove interior panels
- Remove seat belt retractors
- Install SharkBar mounting bracket
- Reinstall seat belt retractors
- Install SharkBar and panels
Took me about 4 hours working on my own at a leisurely pace. Much of that time was spent figuring out how to remove the panels without destroying anything, and then playing around trying to get the bar positioned in the car. That step would go quite a bit easier with a little bit of help, but it's doable on your own.
Sharkbar here also. Here are some pictures of my install, no big deal just take your time plus Dan from Vetteworks is a big help if you have any problems. Or give any of us a call if you need help. JD
Not that hard to do....take your time. I opted for the ultra sturdy Brey-Krause bar. Top notch quality.
Cobra4B helped me install it.
The problem with all of these installations is that they preclude using a HANS device. The shoulder straps are supposed to have not more that 3" between the inside of the webbing straps where they go around the harness bar/attachment point and then go straight forward to the driver. The harness shoulder straps are much too wide when they go around the outside of the stock seat. A sternum strap will not resolve this dilema completely. This probably also reduces the effectiveness of the harness system even without the HANS.
I would suggest considering wearing the stock belts over the harness. I do even though I have Recaros with harnesses because the car/airbag system looks for seatbelt tension on impact (God forbid). When driving I can't tell it is there.
Is there any safety reason not to wear the stock seat belts over a harness? Escape time might be one...
Dan is extremely helpful. In fact, I called him with a couple of stupid questions while doing my install last year, and he took the time to answer them, even though he was on vacation at the time. I'd definitely suggest giving him a call.
Former Vendor
I'm courious why you wouldn't wear a HANS, when you have eliminated the main reason why stock seat guys can't wear a HANS.
Former Vendor
FYI:
Your sub straps are mounted totally wrong!!!
They should be routed back to near (or at) the point that you have your lap belts mounted to. You should be sitting on your (6 point) sub straps not have them routed over the front of the seat. They are almost useless when routed over the top front of the seat.
