Autocrossing & Roadracing Suspension Setup for Track Corvettes, Camber/Caster Adjustments, R-Compound Tires, Race Slicks, Tips on Driving Technique, Events, Results
C6 - 17x11 - Kumho 710s - 315 & 335 Pics
Old 03-10-2007, 12:15 AM
dbratten
Support Corvetteforum!
dbratten's Avatar
Default C6 - 17x11 - Kumho 710s - 315 & 335 Pics
I mounted the tires for this weekend's AAS event at Castle AB and thought I'd take some pictures of the fit. The offset isn't correct but the price is right as I have $1,100 in used tires and new wheels mounted and balanced. I'll give them a try starting at 28psi F and 24psi R. Weatherman's predicting 75-80 deg. for both days.
This is a little dark but both F & R are seen.
The rear 335 side view.
The rear 335 tire showing how much it sticks out.
The front 315 tire showinghow much it sticks out
Another view of the rear with a good reflection.
Old 03-10-2007, 04:39 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
the tires sticking out will chip the crap out of you car so tape it off
Old 03-10-2007, 07:54 PM
C6400hp
C6400hp's Avatar
Location: DFW This user does not support or recommend the product or service displayed in the ad to the right
That looks horrible, hope you don't crack your fenders.
Old 03-10-2007, 09:53 PM
John Shiels
They could crack but my bet is you will see the tires and fenders cut into each other if you turn hard on stock suspension.
Old 03-11-2007, 02:57 PM
dbratten
dbratten's Avatar
Nope, they don't hit the fenders and we're not running moguls so they don't hit bottoming out. The back of the rim touches the tierods when turned near full lock so just need to watch it in the pits. And ... blue 2" painter's tape is used.
To C6 - 17x11 - Kumho 710s - 315 & 335 Pics
Quick Reply: C6 - 17x11 - Kumho 710s - 315 & 335 Pics
