Hey Auto FI guys-where are you mounting your tranny cooler?
St. Jude Donor '08
This is for all the auto FI crowd-where are you mounting your tranny coolers. Just wondering if anyone has come up with a trick setup besides mounting it on the condenser? It get's pretty crammed with the rad, condencer and intercooler.
Thanks!
Thanks!
Supporting Tuner
Duals in the rear...
I do not see how those will be affective since the rear fascia will not allow any fresh air to the coolers. Since there will be not fresh air, they will lose all their cooling ability.
I also have two rear mounted ones, but I have mine located where the stock mufflers would normally be. I am using the Borla XR-1 system, so those locations are not free. By locating them there, there is less overall line distance the fluid has to travel and they are exposed to fresh air.
Keith
Keith
Vette Drs were able to fit a thin strip in the front which seems very effective. My A4 temps have been approx 25 degrees cooler than the coolant temps.
I put my two huge *** B&M coolers in the drivers side vent. Just pull the L/F tire and pull the fender liner and there is a huge amount of room. Hope thuis helped.
Shahram
Shahram
I have my Setrab cooler mounted on the front with no problems; I have the original twin IC kit with one fan too.
Mounted in the rf snout (pass side) front cavity, had to fab/move the horn location but it will fit.
Used a B&M cooler w/fan (like the one in the pic of EG`s car)
temps came WAY down, and that`s before I wired the fan.
The cooler stat turns on the fan around 174*
Keith
Keith
The coolers need to have air flow across them for them to work. If there is not a source of fresh air, the the cooler will be circulating the same air around increasing the temperature of the air. As the air get hotter and hotter, they will draw less and less heat from the fluid.
Keith
Supporting Tuner
^ One opinion. You assume much regarding the rear fascia and the manner in which the final product will be engineered.
Mine is the 24,000 B&M from Jegs. I have Andy's P1 kit, so not much room like u said. He recommended mounting it in line w/ the passenger side brake duct vent. So it is thus mounted betweent the passenger brake duct opening in the front fascia and the wheel well vent outlet by the rotor. Plenty of air flow there.
I'm in the process of mounting a B&M Hi-Tek 70298 cooler in the passenger side of the front fascia. Between the brake duct and the fender. Constructing some brackets to mount unit tomorrow. Anybody who has done this, where did you tap in for the fan power. It would be nice to use the AIR Pump connector but it looks like that doesn't have constant power. Is it possible to tap into the stock radiator fans? Has anyone tried to mount the 70297 cooler. It's the bigger of the 2 coolers. Just wondering how it fit and did anything need to be cut?
Thanks
Thanks
When putting the cooler it the brake duct cavity are you cutting the duct in half or removing it? I wonder how some custom duct on each side of the cooler would work - thus tying it in-line and somewhat sealed up with a fan. Being in the sheet-metal business has me thinking. Wouldn't simply putting a cooler in there keep the heat trapped in the cavity???
HAs anyone tried one of the heatsink type coolers? I was wondering if they work or not. It could be an option.
Heat Sink type cooler.........
