Phoenix Auctions 2007 Engine Pad Quiz #3
Ok here is number three. Lots of '67s at the auction this year. All 427/435.
Real or Restamp ? You guys are the experts, I'm just here to learn.
Cartoon Character
I am no expert by any means , but that 5 looks crooked and odd. Maybe that is normal like my ripply bumpers, but most striking tools line up. I say it is fake - but I would take a real expert with me if I were going to be a buyer.
Fake
Bubba with a belt sander, file, or what ever.
This is just my opinion. The depth of the "broach" marks should vary. As the cutting plate wears, deep gouges should appear. It just makes sense (to me). It is cutting metal to metal.
just my .02
just my .02
No expert here either, but I think the broach marks look good, as well as the overall positioning of the numbers. The "5" is a little off, but didn't those "gang" stamps have a little play in them?
My vote is for real.
Boy I thought this one would fly though with flying colors, but it seems not everyone is together on this one, also.
I thought the little bits of orange paint inside the letters was a really nice touch too.
My assumption the engine was stamped before it was painted and so normally brand new this pad is painted orange. I have also assumed NCRS accepts the removal of the paint on this pad for judging and does not mark off for this.
Again your the experts here.
This car was advertised as "matching number" at the auction.
Some observations:
1. They had to sharpen the 'broach' cutter teeth once in a while so you will have a variation on the finish.
2. Engine plant stamp the only character that will be consistant is the F or the T, the date changed daily and the suffix from one engine to the next. After thousands of engines the holder got sloppy.
3. Vin deritive stamp is same deal as the engine plant, constantly changing.
I'd be skeptical if everything lined up perfectly and had consistant depth. 'Joe' the stamper did not have the NCRS looking over his shoulder. Plus, he didn't give a rat's **** what it looked like.
Real.................................... .enough.
I'd have to agree to that....my signature became a few squigley marks
when I was forced to sign it 300 times per day... After years of that
you're just whippin it through... if it's legible..it's o.k.
Received 1,857 Likes
The assembly plant VIN derivative gang holder dies were changed for every unit that came down the line (the last die every unit, the second-to-last die every ten units, etc.).
Would that then explain why the 71 is so much heavier than the other numbers on the vin in this particular image? IE used more. Or I guess could be just held on that corner rather than level when stamped.
I have a question that perhaps JohnZ or someone else here can answer for me. Was the Tonawanda ID stamp (or Flint as appropriate) struck after the engine is assembled or was it stamped on bare blocks being fed into the assembly process? If after assembly, how does the gang holder clear the pipe plug on the end of the cylinder head? I would assume the plug on BB's would interfere, causing the stamp to shift outboard. Most of the pictures I see here look like the stamps are close enough to the head to suggest they were done on bare blocks before assembly, let alone paint.
I am not calling this one a restamp. Like others, I am here to learn.
Thanks.
- Brad
Thanks.
- Brad
Thanks.
- Brad
Thanks.
- Brad
I don't know when, but I know that.
Thanks.
- Brad
Thanks.
- Brad
Thanks for responding JohnZ. The wealth of knowlege on this website is amazing to me.
I plan to summarize these all the engine pads at some point. Do we have a group agreement on this pad yet?
