[Z06] Halltech Stage 2 is alive! Best mod worth the money! As_ dyno says more HP!
Jim,
Thank you for the great product and your time to help us all get what we are looking for from the Z06!
If any of you are thinking about the Stage 2 mod! STOP THINKING!!!!
JUST DO IT! I love it!
Jim is it me or does my car exhaust at idle sound deeper? I have the stock exhaust fuse pulled all the time and at idle it sounds much deeper and better.
Jim,
Supporting Vendor
St. Jude Donor '09
Jim,
The customer would not let them take it off, and offered to pay for it. This is normally not our policy during testing, but we bit the bullet and let him have it.
You actually have a better, more aggressive port job than the original. We were very careful not to go to big, which ends up causing 1516 codes (Limp Mode) which is a bear to get back home.
The bottom line is that you have our second generation CNC porting, which will go to everyone who has ordered. We have two more initial orders going out Monday, and 11 more being ported next week already sold.
Our next batch will not be done until the first part of February, so those wanting to upgrade Stage 1 to Stage 2, must order and get in line. Porting is not something you can just do with one throttle body. My shop wants a minimum of 10 at a time to make the setup time worthwhile for the cost they are quoting us.
I have not had a chance to fully test this mod with the Tech 2 and WideBand 02 sensors we have onboard, so it will be interesting to see how this affects the overall tuning. So far, it looks like this mod requires NO TUNING
Jim Hall
Ported Throttle Boddy
How much HP does it add jsut itself since a tune is not required?
Location: Works at GT PRO Performance Tuning Modifying C5/6 Z06's in Fullerton CA, WWW.SOCALCORVETTE.COM
We need to get back on the dyno!! Jim and I are REAL curious what it did to your car HP wise, I am really curious as to what it did to your HP/TQ curve, it sounds like you got a good bump in mid range it my guess from your driving impression, but only the graph will tell us what's going on.
After graphing the torque data from the dyno output, it appears that there is a big separation at the 4900 rpm point which is where the claim for 8.8 lb-ft of torque increase is made, it is strange that the difference at 100 rpms higher and lower (i.e. 4800 & 5000 rpm) is only 4.5 and 3.5 lb-ft respectively. It appears that 4900 rpm is an anomoly. A claim of 8.8 lb-ft of torque is nearly double that observed immediately above and below 4900 rpm. Do you get a boost of torque for that split second or can we conclude that the difference is more like 4 instead of 8.8 lb-ft of torque? I would be curious what the margin of error is from one dyno run to the next, if it were 1%, then I would have to ask is there any increase at all? Correct me if I am wrong but doesn't seem like 4 hp and 4 lb-ft of torque is a significant increase and hardly measurable in terms of SOTP. The Halltech tune is clearly a winner and offers a measurable jump from what I have seen but I just don't see what all the hype is all about with the PTB.
Supporting Vendor
St. Jude Donor '09
The LS7 is such a refined machine, squeezing an additional 8 from our F1 Filter and 4 from the beta version of our throttle body, make 12, and Slim Shady had 475.5 RWHP with just our tuning last week. The 2 Stage Filter brings a couple more over stock, but is not the one for bragging rights on the dyno or the track.
There are a lot of folks that have a hard time controlling the stock power on the Z06, and our Stage 2 is not for the faint at heart.
Jim
This is one of three mods that we sell. The combo of the three bring a decent amount of power to the rear wheels for the money.
Jim
Jim
