[Z06] Octane additives/boosters, good or bad...
Living in CA is a pain relative to finding good gas at a gas station. My questions are:
As always, appreciate your feedback...
- Other than the 76 station on Woodside road, where else can you purchase "Gas station" facing fuel in the Bay Area (Southbay)?
- Secondly, do others use "Store bought" octane additives/boosters and if so, which one would you recommend?
I understand that additives will tend to gum up in the fuel lines, carb, or injectors. I have purchased classics before and had to clean out all the gunk from the carbs. I would not use them at all. Just my opinion.
Tetraethyl Lead is what you need to add to the gas. I understand the EPA banned this stuff for use several years ago in unleaded gas. There are a few people who still make it in concentrate. I was using it for awhile, but started buying drums of racing fuel to put in my muscle cars. This stuff works great. Can't remember the name of the place. I'll check my receipts and get back with you.
Cant find my receipts, but I think this was the manufacturer.
http://tetraboost.com/info/
You might contact them to see where it can be purchased here in the USA. There was a company called ? brothers, and they carried this or their own.
You might make sure on your particular application prior to use.
Good Luck
Good Luck
Octane boosters are nasty and I finally sold all this antique iron because I didn't want to carry, store, or add these things to my gas anymore. If I got the 'mix' wrong , especially on the Zs, the engine would knock like heck. The stuff was expensive too.
So my two cents worth is that it makes NO sense for GM to be selling a car for which the recommended fuel isn't even available in half of more of the country and especially cali. Doesn't GM call for 93 in the Z06?
At least in the late 60s a person could still get the 100+ octane leaded premium for the old muscle cars at the time the cars were sold and for several years after. GM has gone that one better and is selling a car that, when new, you can't get the recommended fuel.
I know the engine adapts and I know all the talk about how the hp might drop a bit.....BUT.....IMO the buyer of a brand new top dog Corvette should not have to be adding octane boosters in order to meet factory fuel specs when the car is new. It makes NO sense.
So what, IMO, should GM have done? Tuned the car for 91 octane and set up the engine to make the advertised hp on that octane rating as nominal and recommended fuel.
I also seem to recall ( I sold my last old Camaro 12 years ago ) that it was/is illegal to add lead to a vehicle that was not originally made for it aside from the fact that it might damage the vehicle. So adding lead to an old leaded premium burning '69 might be OK but not in a car meant to run on nothing but unleaded. Like I said I believe it messes up the emission controls tremendously.
Why could GM sell recommended octane boosters for the vette? Well, I would venture a guess that would be because that would highlight the fact that they are sellling a new car for which the buyer cannot get the recommended fuel.
Another little unpleasant possibility on the horizon is that higher octane unleaded requires ( I believe ) more oil to produce that lower octane. Therefore, as international pressures and cost of oil combine we may see the gradual demise of even 91 or 92 octane and be left with only 87 or 88......and , you have to ask yourself, will your Z06 run on that kind of juice? I really doubt it.
For those of you younger than I who cannot imagine a world in which there was no gas over 90 octane let me tell you that we all could not imagine in the early 70s that leaded premium would be gone SO FAST! It was and that killed performance for many years.
It would be wiser IMO for GM to build engines with lower compression that could run on 88 octane as the nominal fuel-wiser that is it they were thinking of owners who just might want to drive the cars into the future instead of parking them because no gas was available.
As an aside I find it amazing that old vettes and other muscle era cars are going for so much money. As a prior owner of such primitive cars I can attest to the fact that they will not run, and in fact the engines may knock themselves to pieces, on current pump gas to say nothing of what kind of alcohol/low octane junk may be available in the very near future.
PS. welcome to the future.
Recommended fuel for C6 Z06
It is a grey area whether the Z06 can make the advertised 505 HP on 91 gas. Again, forum tuners and dyno users please help.
The higher octane gasoline will stay and it does not require more crude oil to make. Actually it takes less crude. The tendency is to use ethanol for increasing the octane rating and other benefits. Most of the gas today in North America contains ethanol. That is not bad and the Z06 was designed to use ethanol blends up to 10% ethanol. See below.
From 2006 Corvette Owner's Manual, page 5-5:
If your vehicle has the 7.0L V8 engine (VIN Code E),
use premium unleaded gasoline with a posted octane
rating of 91 or higher. For best performance, use
rating of 93. In an emergency, you can use regular
unleaded gasoline with an octane rating of 87 or
higher. If 87 octane fuel is used, do not perform any
aggressive driving maneuvers such as wide open throttle
applications. You may also hear audible spark knock
during acceleration. Refill your tank with premium fuel
as soon as possible to avoid damaging your engine.
Gasoline Specifications
At a minimum, gasoline should meet ASTM
specification D 4814 in the United States or
CAN/CGSB-3.5 in Canada. Some gasolines may
contain an octane-enhancing additive called
methylcyclopentadienyl manganese tricarbonyl (MMT).
General Motors recommends against the use of
gasolines containing MMT. See Additives on page 5-6
for additional information.
California Fuel
If your vehicle is certified to meet California Emissions
Standards, it is designed to operate on fuels that
meet California specifications.
California Fuel
Gasolines containing oxygenates, such as ethers and
ethanol, and reformulated gasolines may be available in
your area. General Motors recommends that you use
these gasolines if they comply with the specifications
described earlier. However, E85 (85% ethanol) and other
fuels containing more than 10% ethanol must not be used
in vehicles that were not designed for those fuels.
Octante booster in common stores do NOT work at all. You can buy unleaded racing fuel and mix it in with 91 octane. One of the best race fuels is VP C10. This is unleaded and contains no metals. It has 104 research octane, and 96 motor octane. A couple gallons per 10 gallons may raise your overall octane a point or two. It is something like $6 a gallon.
I have heard that Torco works, but I have never used it.
I use Amsoil 2000 octane booster. I read comparisons on the internet that showed it added about 2 octane numbers to premium gas, so is one of the most effective available in the US. We have 92 octane E-10 so I figured that would be about right. A lot of boosters make outrageous claims but don't deliver.
They dont work. I read somewhere that you have to pour like 20 cans of that octane booster in your gas just to increase 1 octane. (something to that effect)
The gas stations selling pump 100+ octane are the only way to go.
I don't know the 'Vette aplication but I used Torco in a turbocharged I4, 270RWHP/300RWTQ from a 2.4 L.
Added a Forum Vendor! http://www.jbsblownc5.net
Unleaded 6 can case for $95.50 shipped. 1 can(32oz) raises 10 gallons of 93 octane to 104 octane. I used it for a couple of years and had no problems with the fuel system or cats. Haven't needed it in the C6 yet, 93 octane is available at the pumps and I don't see a need for higher octane on a stock w/bolt ons motor.
Joel (JBSblownC5) has been running Torco in his 700hp vette for a LONG time and has had no problems.
You should reach out to him.
I think he is a Torco wholesaler to secure lower prices for himself because he buys a lot of it for his daily driver.
http://forums.corvetteforum.com/showthread.php?t=776542
Now I'm thinking ( I know that could be be a bad thing) So are the non-California cars stronger off the show room? If so them the rest of you need to be very careful - My California Z06 can still scare the be-gebbies out of you
Whatever you do, DO NOT DO THIS!
For good reason.
Name one.
Do you realize this is a "C6 Z06" forum?
If you have olde school muscle cars, then take a trip to your local friendly airport and buy 100LL. It has 4.35 grams of tetra~ethyl lead per gallon...just like the premium gas of the 60's. You'll need an approved container as your chances of "pulling up to the pump" will have security on you big time.
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
What's in 'em ?
Has anyone received MSDS information on the Amsoil and Torco products?
