C4 Parts for Sale/Wanted C4 Corvette Performance Parts, Superchargers, Turbo Kits, Wheels & Tires, Exterior Enhancements, OEM, Aftermarket
Comp Cams XR282HR
Old 01-04-2007, 10:44 AM
padrummer1
padrummer1's Avatar
Default Comp Cams XR282HR
Brand new cam installed one time but removed and put back in box. engine was never fired (or completley assembled for that matter)
XR282HR X-treme Energy Hydraulic Roller
power range 2200-5800
advanced duration 282/288
@ .050" 230/236
lift with 1.5 ratio rocker .510"/.520" (with 1.6 rocker .544"/.555")
all original packaging including cam card included.
from summitracing.com:
Brand: COMP Cams
Product Line: COMP Cams Xtreme Energy Retro-Fit Camshafts
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 2,200-5,800 RPM
Intake Duration at 050 inch Lift: 230
Exhaust Duration at 050 inch Lift: 236
Duration at 050 inch Lift: 230 int./236 exh.
Advertised Intake Duration: 282
Advertised Exhaust Duration: 288
Advertised Duration: 282 int./288 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.510 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.520 in.
Valve Lift with Factory Rocker Arm Ratio: 0.510 int./0.520 exh. lift
Lobe Separation (degrees): 110
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Grind Number: CS XR282HR-10
Get Xtreme performance from COMP Cams.
COMP Cams Xtreme Energy retrofit camshafts are built to take advantage of the latest cam technology, to provide maximum performance. Whether your use is off-roading, towing, or street performance, there is an Xtreme Energy cam available for you. By using an aggressive lobe profile, these cams provide better throttle response and more top-end horsepower than equivalent cams from other manufacturers, while delivering increased engine vacuum.
sells at summit/jegs for $255
asking $200 delivered
Old 01-08-2007, 10:36 AM
padrummer1
padrummer1's Avatar
price dropped.
$150 + shipping
Old 01-10-2007, 05:56 PM
padrummer1
padrummer1's Avatar
sale pending
Old 01-10-2007, 07:34 PM
DanZ51
DanZ51's Avatar
Put me in line if your sale falls thru.
Old 01-10-2007, 09:23 PM
padrummer1
padrummer1's Avatar
will do!
Old 01-18-2007, 02:56 PM
padrummer1
padrummer1's Avatar
sold and shipped.
Old 01-18-2007, 03:47 PM
Z51T56C4
Z51T56C4's Avatar
I don't suppose you are selling the roller lifters?
Old 01-19-2007, 10:38 AM
padrummer1
padrummer1's Avatar
Sorry, I just had the cam
To Comp Cams XR282HR
Quick Reply: Comp Cams XR282HR
