Replaced DRLs with SilverStar Lamps
Old 12-30-2006, 11:53 PM
rtibbit
rtibbit's Avatar
Default Pics! Replaced DRLs with SilverStar Lamps
There have been a couple of threads about doing this, but I thought I could provide a few tips in a new thread.
You can get a pack with two bulbs for $9.95 at Pep Boys. The Sylvania number is 3457AST. Here is a pic of the stock and SilverStar bulbs side by side. It looks like the difference is a dichroic coating on the SilverStar bulb.
The manual for my 2007 has pretty sparse directions on page 373 for changing out the bulbs, but it got me to the right access area inside the wheel well forward of the tire. The back side of the headlamp assembly is hidden by a rubber flap that's fastened to the fender liner with two-piece push-on plastic pins. I turned the wheels to the right to get at the passenger side, to the left for the driver's side, as you can see in this pic of that area with the flap in place.
Another forum member noted that jacking the car to raise the wheel well relative to the wheel provides more room to work. I have small hands and was able to complete the job without using a jack.
You only need to remove the outer three plastic pins that are marked in the photo above to be able to fold the flap out of the way and see the back of the headlight assemby and the DRL wiring and socket. This pic was taken at the best angle I could find, but it is still hard to see the socket - shown by the arrow:
I used a pair of diagonal cutters to pull out the center pin of the fasteners to release them, taking care not to cut the pins.
The socket must be turned about 30 degrees counter-clockwise to release it from the assembly. When released the socket can be pulled straight back out of the assembly. This pic shows the socket released and turned so you can see the rear of the socket; a release tab, discussed below, is marked with an arrow.
The bulb has a bayonet type connection and is removed by pulling it straight out of the socket - it will snap loose. Here is a pic of the socket and new bulb.
There are two keys to getting to the bulbs.
1. The wiring harness to the bulb socket is too tight on the driver's side to allow the socket to be rotated counter-clockwise. The wiring is clamped to the car just a few inches away from the socket. I was able to firmly, but carefully, tug on the wiring and pull enough slack from the clamp to allow the socket to turn.
2. The sockets must be unlocked before they can be rotated in the lamp assembly. This is done by squeezing a tab on the socket toward the center of the socket while you are turning. The tab is on the side of the socket and is difficult to reach, especially on the passenger side. On that side I used a small flat blade screwdriver in one hand to pry the tab while turning the socket with my other hand.
I think it's a good practice to use some silicone grease on the socket and bulb connection when installing new bulbs. The grease helps transfer heat away from the connection and reduces corrosion.
The final result is subtle but looks nice when the lights are off. If you look closely you see either faint blue or faint amber in the center of the DRL - depending on the angle - instead of the strong amber dot caused by the stock bulb. When the lights are on they look exactly the same as stock; I checked after I installed the first bulb and could compare the new and old bulbs. Here are before and after pics:
All in all, this was a little more difficult than I expected, but it's inexpensive and the result is a less busy, more sophisticated appearance for the front of the car when the DRLs are off.
Wayne
Old 12-31-2006, 12:10 AM
SpiralCoupe
Support Corvetteforum!
SpiralCoupe's Avatar
Old 12-31-2006, 05:33 AM
BlackZ51Vett
BlackZ51Vett's Avatar
This post is worthless without pics
Old 12-31-2006, 08:10 AM
ben dover
ben dover's Avatar
Location: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
I did this as well, but was a little disappointed. I was hoping to get rid of the egg yolk look.
Old 12-31-2006, 08:30 AM
BADC64GO
BADC64GO's Avatar
Great write up, thanks for taking the time!
Old 12-31-2006, 09:06 AM
Grumpy
MONARTOR
Grumpy's Avatar
Location: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-10-'11-12-'13-'14-'15-'16-17-'18-'19'-20-'21-'22-'23-'24
where are they?? pretty sure you meant this thread..
Old 12-31-2006, 12:04 PM
rtibbit
rtibbit's Avatar
Default Where are the Pics?
I think "worthless" is a little harsh, but I understand the point.
Since I did the swap without taking off the front wheel or jacking up the car, there was very little space to get the good views and angles I'd like see (I had to work mostly by feel). However, I'll go back and shoot it as best as I can. It would be useful to show the final look. I'll add the pics to the original post.
Wayne
Old 12-31-2006, 12:10 PM
MikeyTX
MikeyTX's Avatar
Received 2,186 Likes on 1,337 Posts
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Heck, he just needs to close his eyes and use his imagination. Btw, I replaced mine too with the Silverstar bulbs. A definite improvement over stock.
Old 12-31-2006, 12:11 PM
Sven
Sven's Avatar
St. Jude Donor '08-'09
thanks for the tech tip. didn't know how much an improvement this made until I was a recent photo on CF. I'm sold!
Old 12-31-2006, 01:36 PM
Carnac
Carnac's Avatar
Nice post - I did the same bulb replament. Nothing dramatic, but a nice improvment.
Old 12-31-2006, 01:45 PM
MikeyTX
MikeyTX's Avatar
NCM Lifetime Member
Old 12-31-2006, 02:24 PM
Grzldvt
Grzldvt's Avatar
I also did this swap... it is pretty subtle. If you aren't looking for it I doubt anyone would ever notice.
The blue color, has a tendency to blend a bit with the LMB, so it eliminates the infamous egg yolk look, but again I would bet 99% of the people walking by the car would never notice.
Old 12-31-2006, 02:41 PM
excessive81
excessive81's Avatar
i did it to. and with one in and one out you could tell for sure. well worth 10.00...or 30.00 depending where you get them...lol
Old 12-31-2006, 04:02 PM
cmb13
cmb13's Avatar
I'm not sure I get it....what's the difference btw this and stock? What instead of yellow or something?
Fwiw, I love seeing another Vette coming towards me with the DRL's; very distinctive look. Can someone post a before and after?
Old 12-31-2006, 06:26 PM
talldude67
talldude67's Avatar
Default DRL input
I'm use to the stock look, at a good distance comin atcha you know the low slung, aggressive look, yellow drl's are on a CORVETTE only. So I'll stay stock. Happy New Year's members....
Old 12-31-2006, 06:36 PM
Zymurgy
Moderator
Zymurgy's Avatar
Received 15,156 Likes on 6,206 Posts
They are still "yellow" when they are on. They just don't look yellow when they are off. Not sure if these are the same bulbs as OP, but this gives you a side-by-side comparison (graphic from GS Creations web site):
Old 12-31-2006, 07:31 PM
MikeyTX
MikeyTX's Avatar
NCM Lifetime Member
Zymurgy, excellent post !
To Replaced DRLs with SilverStar Lamps
Old 12-31-2006, 09:39 PM
calemasters
calemasters's Avatar
I found Silverstars to have a very short filiment life.
Old 12-31-2006, 09:43 PM
MikeyTX
MikeyTX's Avatar
NCM Lifetime Member
Huh ? What are you doing to them? Darn bulb abuser.
Old 12-31-2006, 10:00 PM
hazchris
hazchris's Avatar
I used to get that warm fuzzy feeling seeing yello DRS's coming up in the rear view mirror, even today it happened, till I saw a Malibu maxx pull along side me....buzz kill. the yellow used to mean vette coming, now GM puts them on everything we need a vette specefic color for sure
Quick Reply: Replaced DRLs with SilverStar Lamps
