C1 and C2 FAQ thread
Old 12-30-2006, 01:22 AM
bweaver999
bweaver999's Avatar
Default C1 and C2 FAQ thread
This FAQ contains links to CorvetteForum threads that pertain to items of interrest to both C1 and C2 Vettes. We have not filtered or agree with some of the content, but do plan to provide links to varying positions when available. The intent is to provide a quick link offering assistance on Frequently Asked Questions reducing the need to search for tips. Note that many of these threads contain links to other threads releated to the topic.
Note, this FAQ is a normal message thread. If you see a thread that is likely to be of interest to all, feel free to post a reply with the thread's link. Please do a quick look and verify it is not already posted first. Periodically the the thread will be maintained, certain post links may be moved to main and deleted, posts with no links may be removed, etc. The intent is for this thread to ba a place for truly Frequently Asked Questions. A 50 page FAQ is about as useful as a search that returns hundreds of results.
CorvetteForum help FAQ tips, trics, and pics
Saftey / Garage FAQ (post 2)
Overheating / Cooling (post 3)
Engine and Transmission FAQ (post 4)
C1 and C2 General FAQ (post 5)
C1 specific FAQ (post 6)
C2 specific FAQ (post 7)
Vendor FAQ (post 8)
Manuals / Documentation I should own (available most Vette dealers, shown on Forum Store:
Manuals you should have discussion
AIM (Assembly Manual)
Service Manual
Restoration Guide
NCRS(if doing NCRS restoration)
Books on glass, paint, restore
Other items of interest:
NCRS Judging process
Save the wave
Driver vs. Restored (common on CorvetteForum, NCRS to wild modifications)
National Corvette Museum
NCRS web site
The Corvette Story
C1 Registry.com
C2 Registry.org
63-67corvette.com Registry
What do forum members do (for a living)
Old 12-30-2006, 01:23 AM
bweaver999
bweaver999's Avatar
Default Saftey / Garage FAQ
C1 and C2 FAQ thread (main thread)
Safety Info:
Fire Extinguisher
Fire Extinguisher mounting locations
Emergency kit to cary
Adding shoulder belts (C2)
Adding shoulder belt / third brake light
LED tail / stop light bulbs
Daytime Running Lights conversion
Jacking low lift Info:
Jack stand safety
Jack stands placement
Race Ramp Products
KwikLift portable, drive-on, low-level lifts
2/4 post lift discussions:
Because Of Age, Need Car Lift
New Auto lift, garage info
Car lift, brands used by members
Car Lifts, How practical are they?
Recommendations on 4 Post Lifts
How to wire for lift in new arage?
What brand of car lifts do you guys use?
4 Post lift problems (read entire thread)
Four Post Lift Collapsed - Warnings (read entire thread)
Lift manufacturers (listed lower to higher price):
Direct Lift Pro Park 8 Plus (Greg Smith Equipment)
American Lift Systems, Subterranean parking lifts
Complete Hydraulic
Gemini Auto lifts
DoublePark automobile four-post lift system.
Backyard Buddy
KwikLift 4 post
AllAmericanLifts
BendPak, Inc. - Four Post Lifts
Rotary Lift
Car Lifts (additional manufacturer links in post 7)
Miscellaneous Garage:
Garage / storage ideas
OT - Garage Floor Covering
Garage Floor Epoxy
Garage Journal.com - Epoxy and Tile (Brands+Prices) Flooring
Garage Journal.com - A lot of good info for your garage.
vwtdi (04-08-2023)
bweaver999
bweaver999's Avatar
Default Overheating / Cooling FAQ
FACT, all Corvette's overheat! Popular mis-conception, when they left the factory that was not an issue. Most of these cars run all the time at 180 degrees. Prior to 66, the factory did not set a temperature to define overheating. Starting in 66, the owners manual said 210 was okay. The guess is with big blocks, AC, and emissions starting they allowed for warmer running. Again, most C1 and C2 owners get their cars to run at 180 degrees no problem. Quick Summary to check:
1. Is you gauge accurate? Point an IR gun at the thermostat housing to confirm.
2. Tuning, improperly adjusted timing or carb can cause it to run hot.
3. Re-engineering, the factory stuff works on most cars, especially stock. That assumes the shrouds and correct parts are installed.
The following discussions should help you find a fix so you run cool this summer. Many also discuss re-engineering ideas some of our members have used with success.
Temperature / overheating:
Best all around Engine running temperature?
Cooling 101 and 102 by JohnZ / Corvette Enthusiast magazine from DeWitts.com
Radiator discussion (aluminum vs. copper)
Interesting temperature problem
Another Mid-Year Overheating Problem
New 327 and it wont stop overheating
Water pump / fan checks
Erratic temperature gauge checks
Temperature gauge interesting facts
I Know...another Cooling Thread!/ Adjusting fan clutch
Oxygenated fuel and cooler engine temps (adjustments)
Correct fan clutch
Fan clutch checks
Fan Clutch
Comments on timing and engine cooling
Tuning / overheat
Lar's tuning secrets
DeWitts radiators
Tuning info from BarryK's site:
Barryk's main tech site
Timing 101 by JohnZ
Mapping Advance by JohnZ
How to set timing by Lars
Vacuum explaned by Lars
Vacuum advance spec by Lars
Coolant threads:
Can I use this antifreeze in my 67?
Dexcool and coolant discussion
Coolant recommendations
Coolant drain, flush
Radiator stop leak (Bar's)
Overheating modifications:
Front Air Dam
Alternate wiring for AUX electric Fan
Flex Fan
Lengthy discussion on one member's overheating problem, lot's of ideas / modifications to try
New discussion on 327-350 overheating
Still boiling hot but there is light.
Overheating Problem Solved
bweaver999
bweaver999's Avatar
Default Engine and Transmission FAQ
Engine and Transmission FAQ threads:
Carb / FI:
Carb adjustments
Fuel percolation / hard starting
Fuel starvation/vapor lock?
How to Make A Fuel Line?
Fuel line leakage
Electric Fuel Pump
FI (Original)
FI questions
EFI (after market)
EFI
EFI
Holly Carb leaking fuel
Idle fuel transfer slots
Intake install
Intake. modify after market with oil fill tube
Octane discussion
Ignition:
Coil Failure
How to test coil
Information on timing
Is my timing off
Distributor, Does my distributor need to be re-Curved
Distributor, end play
Distributor, re-build
Distributor, points install question
Ballast resistor
MSD ignition
MSD ignition
Mallory Unilite ignition
Pertronix (points replacement)
Spark plug, Most popular spark plug for Corvettes
Spark plug, type
Timing and vacuum questions
Lube:
Excess oil consumption
Oil type to buy
Oil type to buy
Oil type, ZDDP additives
Oil, Easy to buy hi-ZDDP oil
Oil, ZDDP additives
Posi rear lube
Transmission Fluid types
How much lube in a Muncie?
Muncie 4 speed gear lube
Transmission / clutch:
Convert automatic to manual trans
Drive vs Driven Gears (speedometer)
Cant remove the fill plug on the Muncie
Convert clutch to hydraulic master slave
Hydraulic vs mechanical clutch
5 speed clutch info
Muncie 4 speed grinding
Transmission stuck in 2nd gear
General:
Cam, recommendations
Cam, 3030 Cam
Clean aluminum intake / valve covers
Convert Small Block To Big Block
Clutch replace, parts list - tips
Custom Ram Air filter
Decoding Engine Numbers
Engine rebuild tips
Fouled plugs / Valve seals
Gasket assembly sealer (grease)
Helix coil (repair damages threads)
Max RPM discussion
L79 Engine Build Summary-- Pics, Parts and Specs
LS 1,2 or 6 replacement engine
Anyone who has dropped a LS1 into their C2
Limits to making a 450hp motor look stock?
New engine startup
Parts list for swapping ZZ383 crate motor into a mid year
Power vs. Torque
Re-Stamp numbers
PCV Valve Cover
Valve seal replacement
Securing Valve Covers (stop leaks)
Won't start
Chevy Torque Specs (non-Forum Site)
Engine Pad Quiz #1
Engine Pad Quiz #2
Engine Pad Quiz #3
Old 12-30-2006, 01:24 AM
bweaver999
bweaver999's Avatar
Default C1 and C2 General FAQ
C1 and C2 General FAQ Items of interest to both generations threads:
Your first Vette ride/drive?
Air Conditioning 101
Birdcage / Frame Rust:
Birdcage rust
Birdcage hints and tips
Birdcage and frame rust
Frame rust (internal)
Frame rust
Ways clean rusty parts
Cluster / Electrical:
Alternator test
Battery Gauge
Battery Gauge inline fuse question
Battery Gauge accessibility / removal
Battery Gauge reads -20
Battery Gauge Reading at Cruising Speed
Battery Tender / charger
Battery / alternator tests / charger
Battery disconnect
Best Battery Cut Off Switch - Do you really need one?
Cluster cleaning tips
Cluster removal (67)
Dash light short - extensive electrical checks
Gas gauge inaccuracy
Made a cool tool! (firewall pad/grommet)
Electronic tach conversion
Radio Noise Suppression
Reasons to replace wiring
Should I replace my wire harness?
Speedometer / tach cable lube
Tuning radio to antenna
Wiring diagrams
Wiring harness / component suppliers
Wiper motor rebuilders
Brakes / Steering:
Brake, bleeding brakes
Brake, bleeding with Silicon (DOT-5)
Brake, drum to disk brake conversion
Brake, fluid type
Brake, fluid type, how to check
Brake, fluid DOT 5 long term use
Brake, convert single to dual master cylinder
Power steering conversion
Power steering Jeep vs stock
Steering gear lube
Body / Paint:
Body and Paint Forum
Body on frame paint
Body dolly
Body lift methods
Cleaners and polish
Cleaners and polish (car care forum)
Cleaning, exhaust manifolds
Cleaning, Anyone use DeIonized water to rinse after wash?
Cleaning, Window (Glass Cleaner) Who Makes The Best?
Cleaning, Glass Cleaning 101 Car Care Discussion
Cleaning, Convertible vinyl window
Chassis Suspension - cleaning and paint
EZ Rust Removal
Fixing door for door panel screws? (enlarged holes)
Paint, chip repair
Paint, chip repair
Paint, codes
Paint, How much paint?
Paint, How much for a pro paint job?
Paint, Make a paint booth
Paint, Paint shop questions
Paint, prep (gel-coat)
Paint, prep
Paint, tips
Paint, type
Paint, type
Paint, Strip
Paint, Terms used
Paint Question... Roll-on Primer?
Scratch removal
Scratch removal
Should I do a body off restore / cost
Stress crack repair
Best vendor for Windshield glass
Matching Numbers:
Engine pad matching numbers
Should I go original or custom?
Trans and diff numbers
When was my car built?
Value / Price / Cost:
Average dollars spent
Market Value information (web sites)
Stated or Agreed value Auto Insurance?
General Market Value Info
Corvetteblogger.com articles on Corvette buying, selling and pricing
Car purchase advice
Financing ideas
Ebay bid tips
NOM (Non Original Motor) price deduction
Who insures your car?
Estimating Restoration Prices.
Other:
Adding AC
Adding AC (detailed writeup)
Adding anti-theft
Alarm system
Inexpensive GPS theft protection
Automatic trans (newer generation)
Dash restoration
Fix for enlarged screw holes
Front end shakes
Gear ratio (explanation)
Gear ratio, Determine your rear gear ratio
MagicV8 personal Corvette web site (interesting ideas/ tips)
NOS- A Detailed Explanation
Projects (easy)
Replace front coil spring (tip)
Restoration tips
RestoRod (newer frame swap)
Shifter rattle fix
Steering Wheel Size
Tilt wheel conversion
Tires, Found a spare that fits the tube and cheap!
Tires, High speed vibration
Tires, Nitrogen in tires
Tires, new looking but old tires ?? - caution
Tires, Radial tire alignment
Tires, Spare tire Questions
Wheels, Anyone use Gibbs Brand Penetrant to preserve aluminum wheels?
Wheels, measure offset / back spacing
Winter storage
Wheels, see different options on your car
Other interesting sites:
Barryk's Corvette Tech tips site (a lot of tips / articles)
BlackMagic's site (modification tips / details)
CorvetteWorld (lot of good info on C1 and C2
The Idaho Corvette web page
Web-cars.com/Corvette
bweaver999
bweaver999's Avatar
Default C1 specific FAQ
C1 specific information FAQ threads:
3 speed to 4 conversion
4 way flashers for a C1
5 speed
1957 Airbox Corvette - What is it?
1957 Original AIM - Scanned Available for Download
Battery guage
Body off
Chevy C1 Publications - Public Domain Stuff
Electronic Tach And W/shield Question
Finding Parts for a C1
Gas tank with built-in elec fuel pump return line
Martz Independent front suspension C1 opinions
Rear springs
SRIII chassis (C4/C5 chassis)
Convert to C4 suspension)
Steering wheel "play"
Tire / wheel sizes
Tire / wheel sizes
Tire / wheel sizes
Tire / wheel sizes
Tire / wheel sizes
Tire / wheel sizes
Traction improvement
Traction Master update and finish
Wheel Bearing Adjustment (disc brake conversion)
C1 wiring harness tips
61 resto mod (details)
http://www.earlycorvettes.com - A lot of good info on early Vettes, pics etc.
bweaver999
bweaver999's Avatar
Default C2 specific FAQ
C2 specific information FAQ threads:
Exhaust:
Chambered (under car)
Headers
Mufflers
Side pipe poll
Side Pipe Conversion
Side Pipe Conversion Kits
Side Pipe Discussion
Loud side pipes and an idea.
Side pipe crossover pipe instl and soundbyte
Side Exhaust HELP!
Interior:
Cluster repair
Cluster Removal
Cluster paint
Gas guage trouble (C2 quick checks)
Gas gauge checks / sender tool
Gas gauge sending unit quality
Inside Door Pull Repair
Leaks, The 65's first wash. It wasnt pretty
Leaks, 1965 Convertible Waterfall
Installed Eklers 3 point seat belts
How To Disassemble 67 Seat Belts?
Seat Belt Restorations
Water leak tips (windshield)
Wiper Switch Removal
Suspension / brakes:
Alignment cost
Alignment specs
Alignment specs, radial tires
Alignment / body leaning
Emergency brake adjustment
Noise in Rear End
The Life of a vette posi
Rear Wheel Bearings
Rear wheel bearing check
Rear Wheel wobble
Offset Trailing Arm
Power Steering Control Valve leak and Rebuild
Hydratech Braking Systems (C2 hydraulic PS brake booster)
Jeep power steering box or Factory style?
Speedometer gear selections
SRIII chassis (C4/C5)
Suspension Upgrades
Do you like your monospring?
Trailing arm re-build (pictorial)
Trailing arm replace
Trailing arm replace2
Trailing arm, Using French Locks C2 half shafts
Tires and wheels:
Pics of various wheels on C2 (Black_Magic's site)
Tire, Size
Tire, Options
Tire, Performance Tires
Tire, Wheel Options
Wheels, 17 Inch Rims
Wheels, Knock Off Wheels
Wheels, Knock Off Wheels Removal
Wheels, Knock Off vs Bolt On Wheels
Wheels, "New" Knock Off wheels
Wheels, Large Wheel
Wheels, Rally Wheel Size
Wheels, Rear Wheel Fit
Wheels, Torque Thrust
Wheels, Torque Thrust Wheels
Transmission:
5 speed
5 speed
6 speed
Other:
Body off project
Best non-stock improvements
Door hinge pillar
Hardtop re-build (pics)
Headlight adjustment
Headlight aiming
Headlight motor assembly (re-build)
Headlight motors (quality)
How to remove Headlight Buckets?
Hoood alignment problem
Headlight motor removal
Headlight warning lamp
Headlight bucket removal
Gran Sport Kits
Gran Sport Kits II
Loose side mirror
Original big block??
Rear harness, pictures
Rear View Mirror - Glass Replacement
65 resto mod (details)
bweaver999
bweaver999's Avatar
Default Vendor FAQ
Vendor web sites
Which vendor do you like? Vote here.
The purpose of this FAQ post is to provide a quick link to popular vendors for C1 and C2 parts. It contains links to sites outside of Corvette Forum. All links should work as of the last edit date. It contains links to non-Corvette specific sites puled from various threads along the way, you may find them useful for resto-rod cars.
Please do not add vendor comments positive or negative to the FAQ thread, use the Vote thread above or start a new on for that.
Posts in the FAQ thread should include a link to vendors not listed below.
General Corvette vendors listed alphabetically:
Bair's Parts
Cannons Corvette (new and used parts)
Corvette Central
Corvette Forum Store (Zip)
Corvette Specialties Of Maryland
Corvette Stainless Steel Brakes
Ecklers
Keen Parts
Long Island Corvette (C2 only)
The Last Detail
Mid America
Paragon Corvette Reproductions
Vette Brakes
Volunteer Vette Products
Willcox Corvette
Zip Products
Specialty Corvette products / non-Corvette listed alphabetically:
Al Knoch Interiors
Corvette Steering (Power Steering Conversion)
Corvette Rubber (various rubber items)
Corvette Stainless Steel Brakes, Power steering conversion
DeWitts Radiators
Dynamat
Gibbs Brand Penetrant Oil
5 Speeds (5 speed & Muncie 4 speed)
GM Parts Direct
Guldstrand Motorsports (suspension)
JEGS
Keisler Engineering(5 speed)
Lectric Limited (Wiring Harness)
Wiring Ron Francis (connectors, etc)
Connector source Front Parking Light mod
SSnake Oyl, seat belt refurbish
SRIII C4/C5 chassis for C1/C2
Summit Racing
SpeedDirect (Steeriods)
Vintage Wheel Works
Van Steel (Suspension, brakes, off-set trailing arms)
Vette Brakes & Products
Vette Works (Fire Extinguishers, suspension and brakes)
Virginia Vettes (Wheels, re-build service)
Crate Engines:
BaddAss Engines
Engine Factory
GM Parts Direct
JEGS
Summit Racing
Stroker Motor
World Products
Re-build services:
Corvette Instrument Service
Eirc Freeman E-mail drvettejr@aol.com (no web site, Teak steering wheels)
Jason Oliver E-Mail VetteInstruments@aol.com (no web site, cluster re-builds)
Vintage Plates (thread has URL's)
John Pirkle Re-Build Electrical
Vintage Wonderbar Delco Radio Service
Joe's Classic Car Radio AM-FM
Old 12-30-2006, 01:25 AM
bweaver999
bweaver999's Avatar
Reserved10
Hope you find this usefull, reserved a few posts in case needed in the future. Tried to gather items that I may find useful in the future, also post on topics that are asked repeatedly. GreyGhost started the idea, worked with him a while and he got busy with work so I posted it.
If you see something that should be added, please post a link. I tried to group things togetner alphabetically, some may be a bit off but believe it's a good start.
The following 2 users liked this post by bweaver999:
Gofltn1 (01-28-2017), ptjsk (11-14-2021)
Old 12-30-2006, 03:10 PM
Romulus1960
Romulus1960's Avatar
Can we get it stickied so us noobies can point other newbies to it?
Great start.
Old 12-30-2006, 03:23 PM
crw41
crw41's Avatar
Well done
Old 12-30-2006, 04:21 PM
PeteZ
PeteZ's Avatar
Originally Posted by bweaver999
Reserved10
Hello Bruce,
Congratulations to you for your hard work and dedication on providing this excellent FAQ library resource to the Corvette Forum .
Happy New Year and best regards,
Pete
Old 12-30-2006, 05:01 PM
67vetteal
67vetteal's Avatar
Absolutely Wonderful!! What a great asset for our members. Thank You! Al W.
Old 12-30-2006, 05:09 PM
bweaver999
bweaver999's Avatar
Great start.
Requested it on the help forum. Hopefully next year!!!!
Happy new year to all!!!!!!!!!!!!!
Old 12-30-2006, 07:01 PM
Jim Dillon
Jim Dillon's Avatar
Bruce, you and Grey Ghost deserve a lot of credit for the hard work. It will be very beneficial to all of us, thanks-Jim
Old 12-30-2006, 07:04 PM
richbopp
richbopp's Avatar
Location: Park City to SoCal - according to the map it's all down hill. No bad days in Indian Wells, California
Thank you so very much. have spent some time in the threads already and they are so very valuable. Great work.
Happy New Year and again I say, Thank you
Old 01-01-2007, 01:48 PM
Kensmith
Support Corvetteforum!
Kensmith's Avatar
Now this is some great stuff........nice job!
To C1 and C2 FAQ thread
Old 01-26-2007, 02:51 AM
wmf62
wmf62's Avatar
St. Jude Donor '07
thank you.....
Bill
Old 01-30-2007, 07:03 AM
vic z
vic z's Avatar
thanks for putting this together.some very useful info !!
Old 03-21-2007, 06:22 AM
vic z
vic z's Avatar
[QUOTE=vic z;1558737359]thanks for putting this together.some very useful info !!
