Aligning rear body/rear spring problems.
Well, spending time under the new 65 and finding some issues. The car sits lower on the passenger side so I am trying to level the rear of the car. I did notice the two large bolts that connect either end of the spring to the trailing arms were not adjusted equal. So I attempted to make them equal length which of course made the car even more unleveled. So I went to the extreme with the passenger side bolt tightened as far as possible and the driver side backed off as far as possible and that really looks ugly from under the car but did help a little. The driver side body is still higher than the passenger side by about 1/2 " but is the problem with the rear spring? Or bad trailing arm? Or something else? Thanks
Ken
Ken, the spring could be sagging on one side. When the car is sitting on level ground is the spring flat, curved down or starting to invert? How are the 4 spring cushions-the ones at the top and bottom of the bolts you spoke of? Squished? If so you may try replacing them and then see where the spring is and make an adjustment in height.
Ken
Ken
Spring is not flat or sagging. Has good curve to it. Rubber cushions are squished but equal on all sides. If I had to guess, I would think trailing arm. But that would just be a guess. I am still learning.
Spring Height
If the spring is very old or original, it may have lost some of its tension throughout the years. It could still look OK. My 68 listed until I changed out the spring. I would also look at the frame for signs of obvious rust. Best to put the car on a lift and do a thorough inspection. I am hoping for a bad spring. It is an easy and rather inexpensive fix. Jerry
Ken, if will also make a difference if your measuring the chassis height or the body height. The factory GM service manual tells how to determine if your suspension is setting at the correct ride height (within tolerance spring sag, bushing wear, etc). Even if your car passes this measurement the body may not sit level on the chassis for several reasons (shim pack dimensions, body mount cushion deterioration, body assembly tolerances, body damage repair, etc). I would measure the ride height according to the GM service manual and if everything checks out OK, leave it alone for now. The body on these things are never perfect and if one sits absolutely level from side to side on a frame - it's a fluke. If you ever tear down the car to restore, or decide to replace the body mounts, at that time you can play around with the shim packs a little to level the body up to some extent.
Dan
Dan
Received 1,843 Likes
You can also stick a spring doughnut under your right front coil spring to kick the left rear down.
As stated, there are many possible reasons for your list. You might put the body on a frame rack, check all the suspension, could have an unhit body and the thing will still have a little list to one side with everything "in spec".
A half inch isn't much but it's just enough to bring visual attention to it.
Think what I will do for now is set the rear spring at the same height at both sides. Then take a couple of photos and post them. Maybe it's normal and the difference from side to side is about 3/4". Not a big deal to most but I am one of those guys that has to have everything right. just finished re-aligning bumpers, hood, and now trying to level the body. The car is a good car, just neglected for awhile like most old cars. I will never do a body off because this is going to be a show/driver when I am done. But the car has to sit right, drive right, feel right, and then look right. RIGHT!
What do you think could be wrong with the trailing arm? Unless it was rusted so bad it sagged there should be no issue with the arm relative to ride height. These cars did not alway sit level from the factory. I have seen very original low mileage mid years with 2 and 3 of the large washers installed from the factory on the spring bolts to compensate for the car sitting too low on one side.
Have you determined whether or not the frame is the same height off of the ground on both sides of the car? Possibly your body mounts are decaying allowing the body to sit lower on the frame on one side versus another, in which case adjusting the spring will simply compensate for the real problem.
Somebody touched on it in an earlier reply, but a bad front coil, can make the rear uneven as well, even though the front looks fairly level.
Doug
Doug
That will be the next thing I check. Probably the easiest is to replace the rear spring and bushings. Then if that does not help, go to the front coils. I don't see how one side of a rear spring can be weaker than the other but that seems like the logical place to start unless there are others who have had the same problem? I will do a visual to the front springs in the morning. Maybe one was replaced at one time?
It could be that if the front end had been rebuilt in the past that one of the coil springs are not seated properly. Also I know that from past posts there was an issue or question about the rear camber. If one side has more camber than the other it will sit differently. Can you post a pic of not only the rear spring but also a side shot looking at the rear forward? Dave
Location: going faster miles an hour...with the radio on in browns mills new jersey
How about if you jack up the front of the car so that the wheels are off the ground and both sides of the frame [at the front] are the same distance off the ground. This would eliminate the influence of the front springs on the rear of the car. Then measure the back and see what is going on. No sense just buying parts for no reason. You'll be buying enough of them as is.
