AeroForce Interceptor OBD-ll in A-pillar
00 C5, 05 CTS-V
Anyone ever try this? It is more than a reader as it records also. The best this is that it can display more than one input.
http://www.aeroforcetech.com/
Thanks,
Norm
Thanks,
Norm
Supporting Tuner
I like that it does this - "Knock Retard"
Beats running EFI Live all the time logging to see if you are getting knock
Love mine, but it causes issues on the C5's data buss; resulting in error codes. The manufacturer recommends running the scan gauge at a slower scan time, but this hasn't helped mine. <shrug>, still like it though.
00 C5, 05 CTS-V
I loved my Interceptor in the GTO and really want to put one in the ZO6 I eventually buy. Is there anyone using one successfully?
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
OK,,,,,,,,,,,,,,how much is this thing??
BC
BC
I'm guessing that it would fit nicely in a pillar pod. Having analog-in is handy if a parameter not measured by the OBD II needs to be displayed. An intake air pressure differential would be great to see when it's time to change the air filter, but intake air temp is also nice to know.
I like the possibilities of this thing!
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
I Believe In The Beer Fairy
Interesting. I'm going to contact the company with some questions. Looks like a pair of those in a pillar pod with a hookup to a wide band O2 would show PLENTY of info to run around and watch.
I just got an e-mail back from one of the companies that sells them (not a supporting vendor), and they said AFR could be displayed on there, but it'd have to be wired up by the purchaser. You'd use the analog 1 or 2 pins for that. It's a nice looking unit, but if I want to log using EfiLive, then my gauge won't work because I've got to plug into the OBDII port.
Pro Mechanic
For those who have one installed in a C5 Z06...
"Not all are supported by every vehicle, so there is no guarantee that the Interceptor will display all of these on your particular car
or truck."
The Z06 has a tranny temp sensor, does this unit, when installed in a Z06, display the transmission temp? (would really like to monitor this while on the road course...)
thanks!
MBDowney
or truck."
thanks!
MBDowney
Anyone have updates?
Do you have any issues with the gauge or throwing codes from it or anything like that? Thanks!
Overall my scanner work 99% of the time during warm weather and about 80% when it's cold.
Interesting, I never had as single trouble code with mine in the GTO.
