[Z06] Can Anybody Fix a Twitchy C6Z???
St. Jude Donor '09-'10
There have been a number of posts referring to the C6Z as twitchy, so I don't think I'm alone. For example, you almost have to hold on for dear life--or at least with both hands--when you hit a bump at any speed or it will throw you to one side or the other. This happens whether I'm running the stock run flats or my Michelin Pilot Cup Sports.
I'm sure there has to be somebody who can set this car up right. The first name that comes to mind is LG--but NJ is a long way from Texas.
I went to Phoenix Performance in PA and was almost willing to give them a blank check to fix the problem. But all they did was a $300 alignment, which solved nothing.
Any suggestions? If I can't get it fixed, I'm thinking of selling the car.
Man, you are going to sell the car if you can't fix it? I think I know what you mean. I have experienced moments, on rough bumpy roads where the Z seems to bounce from one side to another as it hits bumps. But overall my car performs awsome. I wonder if yours is worse?
I always attributed it to the runflats being stiff. And you have tried other tires, non-runflats? Hate to see you have to sell the car over this. I am sure something can be done, but it may cut into the performance handling of the car.
better shocks or coilovers from LGM no reaso for it to be twitchy. People complain about Lime Rock being bumpy. I have real stiff suspension but never feel it because of proper dampening and the car is always under control. Hope your not talking speed bumps at 75 MPH
This is a hot topic for the SRT guys on the Viper site. The Viper is with out a doubt 2-3 times worse than the Z.
Many guys on the Viper site claim an improper alignment can be blamed.
Many say the tires.
IMHO it is not the alignment. The car tracks in the surface texture of the road. Especially now that you say Pheonix didn't make it better.
I am convinced it is the wide tires and tread pattern.
I have learned that the best thing to adjust is your grip on the steering wheel. If you hold the wheel too tight you actually send messages to the steering and it will respond without you expecting it to.
By loosening the grip of your hands it is easier to not over reactor over correct( which is natural) to the steering issue or jerky feeling. Part of the jerky feeling is the driver trying to correct the situation and actually you over correct.
I know it sounds crazy but it works well for me.
Many say the tires.
It is the very wide tires combined with ruts in roads heavily populated with large trucks. Any car with wide tires suffers from exactly the same behavior on such surfaces.
Put skinny tires on it.............the problem will go away, but others might surface.
IMO It was a combo of the (very) precise steering rate, the fat tires, and a long wheelbase.
I also noticed it rode more stiffly and "bouncy" - but I dont really consider that a negative....
I also found out the Brembo's on the Viper work VERY well
There have been a number of posts referring to the C6Z as twitchy, so I don't think I'm alone. For example, you almost have to hold on for dear life--or at least with both hands--when you hit a bump at any speed or it will throw you to one side or the other. This happens whether I'm running the stock run flats or my Michelin Pilot Cup Sports. Any suggestions? If I can't get it fixed, I'm thinking of selling the car.
Try different tire pressures and see.
I would suspect taking a few pounds off the fronts may help.
Try to hold the steering wheel absolutely still when going over pavement discontinuities. See if that helps the Twitches
It actually ran well at Lime Rock, but not that well at VIR and The Glen. In fact, I hit a guide rail at The Glen--which, admittedly, may have been my fault for taking it beyond my limits. Nevertheless, I did more than 25 track days with my CTS-V and a C6 at Pocono, Summit Point, The Glen, Lime Rock, and VIR and never had an incident. By comparison, my C6 (which I traded on the C6Z) always felt like it was running on rails. Starting with when I took it from the dealership, I've never felt that way with the C6Z. Now with 14,000 miles and three alignments, it feels twitchier (if there's such a word) than ever. If I can't get it fixed, I'll go back to running my CTS-V at the track.
What's old is the bitching, by those who DON'T KNOW HOW TO DRIVE a Corvette, that the Z06 is "twitchy". I'm not taking it personally, I'm arguing a point. And the point is complete BS.
LEARN TO DRIVE your car, and the car won't seem "twitchy" to you. Don't think that you can LEARN TO DRIVE a car after 10-15 minutes behind the wheel. It takes a lot of years.
Get a clue.
Get some driver education.
Get behind the wheel and LEARN TO DRIVE your God damn car.
The more you bitch about it, the more I'm going to slap you around. Consider it a mission of mine. :-)
jas
Get a clue.
jas
Until you actually drive my car, it's moronic for you to come up with the conclusions that you have.
But, of course, your posts have shown that you know everything about driving a C6Z, so perhaps I should bow to your greater knowledge.
So maybe there is something very strange wrong with your car that we can't relate to not having experienced it, but if that is the case, you gotta admit that it might sound a bit odd to us. Hence, the reactions you received.
Sefa, the quote in bold just sounds very strange to most of us, who also have some experience with this car. I've been to Spring Mt. too, and I don't ever recall thinking I've had to "hold on for dear life" on either street or track in a C6 Z06.
Slight corrections were all that was needed. There was no sawing at the steering wheel at all.
YMMV
Many say the tires.
Many say the tires.
