COLD AIR INDUCTION / DIY / "How To" write-up
Cold Air Induction
Here is a cold air induction you can do yourself with your stock parts. You will need a washable
filter (K&N or Green) and some Tie Wraps.
Essentially it is the bottom and filter frame of the stock airbox flipped over, fitted into a hole cut
into the radiator shroud. All held together tightly using Zip Ties and the stock clamps.
A "Write up" for download is attached at the end of this post.
_______________"FLIP-TIE"_________________
___________________________"FLIP-TIE"___________________________
________________________"DO IT YOURSELF"_______________________
Download Write-up here
nice write up,i did the mod last friday after studying your pictures friom your previous thread.all went well,i'm happy and it's gotta be better than stock!
Superb how-to write-up. One of the best I've ever seen, and yours is easily 200% better than most instruction sheets created by aftermarket vendors (you know who you are).
Originally Posted by nighteu4ia
mixermike, was it worth the mod. can u tell a differenc in performance etc..?
Received 19,547 Likes
'20-'21-'22-'23-'24
Good write up. Thanks for posting it.
Originally Posted by C5FORFUN2
How do you like all this snow and ice? Corvette works surprisingly well.
