Need help decoding engine numbers please
Hi, I just purchased a 327 engine and the owner didn't know what it was from but I believe it may be from a 66 'vette. Here are the stamping numbers:
Rear engine block (near bellhousing): 3858174
Pad in front of passenger head: FO7II2AS
Heads, under valve cover: 3890462 & F276 & GM15
I would GREATLY appreciate anything you can contribute to helping me decode this engine. I have my fingers crossed that it's something I can use for my first rebuild. Thanks in advance! Malo
St. Jude Donor '05, '09, '15
I am not real good with this numbers stuff but this what it looks like to me.
3858174....327...64-67
3890462....66-67...302/327/350..Camel hump,no accessory holes,64cc chamber
F276 I think is June 27 1966
Received 1,857 Likes
Here is a tracing from the pad stamping:
Looks to me like its FO71I2AS?
07 = July
1I = the 11th day
2AS = ???? As John stated there should only be 2 characters not 3.
FYI, it would not be a Corvette engine with an AS- according to Noland, all 66 327's started with a H or a K, not an A. Most had 461 heads, but 462's showed up late in the production year.
The extra digit makes it a plant stamping error or a restamp error maybe? If the engiine looks like it is original, not decked or bored, it may have been a GM production error.
Don
Don
Don
Don
The only 60's Flint engines I've seen with odd 3-digit suffixes were marine engines (Mercury Marine, Crusader, etc.); that's probably where that one began its life. With a very few rare exceptions, there were no 3-digit suffixes until 1970.
Hi,i' m lost!
I have a 63 vette(NOM)
My engine number reads 12118112F0206SB
I'm from downunder(Melbourne Australia)and ,after all my research, can't work out what this engine is!!!!!!!
Can you please help?
Regards
John
Regards
John
The "SB" suffix was used on '62-'64 327/300hp in full-size cars; the VIN derivative stamping on that one says it's from a '62. What's the block casting number (U.S. driver's side rear flange) and the casting date (about 5" toward the U.S. passenger side from the distributor)?
Engine number.
This is all the information i have at the moment,i dont have the car yet
as it is just about to be loaded on to a container for shipping to Melbourne,Australia.
I only have photos of engine,not sure if this helps.
Received 1,283 Likes
I recently helped a friend sell a 64 Impala with a 327 / 250 hp engine, full option car (S suffix code). The pad did not have a VIN derivative.
Perhaps this varied from assembly plant to assembly plant as the VIN derivatives were phased in throughout the 60s.
Pretty unusual to find a 62-64 low hp (250 / 300 hp) engine in a passenger car with a VIN derivative on it.
Verne
