distributor end play
Old 11-15-2006, 02:06 PM
rowingone
rowingone's Avatar
Default distributor end play
I got my shim kit that Lars recommended but wanted to make sure that these go on the shaft after removing the drive gear? How do I measure the end play so I know which washers to use? Thanks!
Old 11-15-2006, 02:16 PM
Scott Marzahl
Scott Marzahl's Avatar
You need to remove the gear, make sure you pay attention to the dimple on the gear, it needs to align with the rotor. There should be a shim or two already above the gear so just add as needed. Use a feeler gage to set your axial play.
Old 11-15-2006, 02:31 PM
Donald #31176
Donald #31176's Avatar
Before removing the end gear measure the play between the gear and distributor housing with a feeler gauge. (example the play reads .045 ")
You need to add about .04 in shims to get within the .002-.007 spec.
Old 11-15-2006, 02:35 PM
rowingone
rowingone's Avatar
Thanks . . . that's what I needed!
Old 11-15-2006, 05:00 PM
rowingone
rowingone's Avatar
Where does the advance stop bushing go . . . I'm looking on the mech advance and there is no place large enough for the bushing??
Old 11-15-2006, 05:05 PM
ctjackster
Support Corvetteforum!
ctjackster's Avatar
underside of the top of the shaft, it goes on the nub that rides in the slot in the cam, if that makes any sense . . .
Old 11-15-2006, 05:17 PM
GOSFAST
GOSFAST's Avatar
Default Cam/Distributor Gear Oiling
While your setting up the end play take a few extra minutes and
"modify" the lower oil passage band on the housing to get more oil down directly to the gears where they meet. It will extend gear life immeasurably. We perform this mod on all distributors now, especially with the "Bronze" gear on the steel cams. Works well on all units and very simple to do! Thanks, Gary in N.Y.
P.S. Here's a photo of the procedure taken from directly from the
"Crane Cams" catalog.
Old 11-15-2006, 05:24 PM
rowingone
rowingone's Avatar
Thanks got the bushing figured out . .. and GOSFAST . . great easy tip . . . that costs nothing . . . I love those!
Old 11-15-2006, 07:01 PM
DansYellow66
DansYellow66's Avatar
Received 2,615 Likes on 1,947 Posts
Be careful that you don't over-shim. The amount of end play out of the motor may be greater than the amount of end play when installed in the motor with a gasket and tolerances, etc. This will bind it up to some degree and definately isn't a good procedure. When installed back in the motor you should still be able to have a some very slight movement. Probably checking shaft end play with a dial indicator set up in the motor is the best approach.
Dan
Old 11-15-2006, 10:30 PM
67L36Driver
67L36Driver's Avatar
Dan
You can check for any clearence with a feeler guage under the mounting flange by installing the dist sans gasket. If you have a gap there you can subtract a shim from the stack. The gasket will provide enough extra clearence.
Old 12-29-2006, 02:08 PM
jtranger
jtranger's Avatar
Where can I get a Vacuum stop bushing? Larry
Old 12-29-2006, 02:26 PM
lars
lars's Avatar
Received 4,916 Likes on 1,928 Posts
Just use a vacuum advance that meets your spec requirements - skip the vacuum stop bushing. For most performance applications, the VC1765 (NAPA) is ideal. If you have a big cam and low vacuum, run the VC1810. These will get you 16 degrees of vacuum advance without a bushing, and that's perfect in combination with a 36-degree total advance curve.
On your shaft endplay, don't set it tighter than about .007", although I've successfully run them down to about .005" without galling the shims. You have to have a little space for expansion and contraction of the parts under temperature. On the aluminum-housing distributors, you have to run the endplay at no less than .010", with .015" being preferable.
When you install the brass mechanical advance stop bushing, smack the bushing on the side with a hammer before you install it to make it a little oval-shaped. This will make it fit really snug on the pin. If it doesn't fit really snug, it will eventually fall off, and it will ground out your points if it falls in just the wrong place (I've seen it happen twice...).
Old 12-29-2006, 02:29 PM
Donald #31176
LICS has a good selection of 62-74 distributor parts. www.licorvette.com
To distributor end play
Quick Reply: distributor end play
