'65 Vert Shoulder Belts?
For safety sake, I'm interested in replacing the standard lap belts with shoulder/lap belts for a '65 Convertible? Difficulty of installation? Drilling the mounting holes? Model or type to buy, & vendor to purchase from? Approximate price? Etc, Etc?
Received 1,857 Likes
Nope, no web page - just call Charlie - great guy to work with.
There is a place in CA that makes a custom kit...it does require a hole or two in the fiberglass. I have been considering it myself. It is the same place that does the custom auto sound stereos, but there is some other division that does the belts (same offices)...I think you can just call customautosound.com tell them what you want and they could connect you.
Thanks for the info.
I was a little concerned about ordering seat belts and installing them. Sooooo-after a lot of research and web & catalog searching I think I found what I was looking for(?). I've had generally good luck with Eckler's stuff and in their C-2 Spring/Summer Catalog (page 36) they have a 3-Point Retractable Seat/Shoulder Belt "Harness Retroffit Kit" with downloadable colored photograph installation instructions----so I went ahead & ordered them. So we'll see.........I'll post the results after they are in---if other's are interested.
Originally Posted by Rimcrew
Please do. I would like to order this setup, if you are happy with it.
TIA
TIA
Why would you need the cable? That is for the 40-gallon tank setup.
How much further forward is that rear mount plate than this stock setup? I am considering your project as well.
I have e-mailed Eckler's re the availability of saddle 3-point belts. Apparently they are not now in stock. No reply. If you are happy with them, and they become available, I will order.
If you hit something hard enough to pull the anchor plates through the fiberglass I don't know what extra insurance a cable would offer.
Paul, visit an accident scene. A real education.
I ripped the bucket seat in front of me out of the floor once; ripping an anchor plate though some fiberglass ain't nothing. I'd want the cables if it keeps my face off of the steering wheel or my passenger's face off of the grab handle. . . .
3-Point Shoulder Belt Order
I ordered black ones about a week or so ago and did get an e-mail confirmation from Eckler's for delivery this Tuesday..... However, it may be a week or two before I get them installed--Holiday's, etc. But I'll let you know how well I like them & I'll take some pix.
TE.
TE.
St. Jude Donor '05, '09, '15
Thanks
CT,
I haven't see a Corvette accident that bad but I take your point.
Sky,
I am working from my photo archive as my car is in dead winter storage and I won't see it until April. This pic is the best I can do. The shoulder and lap belts are independent systems, each with its own buckle. So essentially you buckle up twice. It's bit of a pain hence the 3-point has some appeal. It would be nice if the 3-point could use the stock rear mounting anchor rather than me drilling another set of holes.
Sky,
Paul, If you look at the Ecklers instructions for a 1968 or1969 it tells you to use the factory locations. 68 shoulder straps are the same length as 67 and bolt to the same plate that is used in 67. The location looks to be in the same place.Find a friends 68 or 69 and measure it.
If it were my car I would try them in the factory location before I drill extra holes.You can always move them later. Clete
Clete,
I will look at the 1968-69 instructions. Thanks for that tip. The C2 instructions say to measure 5" back from the inner door trim. That is not very far back. Hence my confusion.
*Edit* - Those instructions do say that the original mount holes can be used. There may be hope.
