Autocrossing & Roadracing Suspension Setup for Track Corvettes, Camber/Caster Adjustments, R-Compound Tires, Race Slicks, Tips on Driving Technique, Events, Results
Alignment, DTC, and torque PDF's
Old 11-13-2006, 02:23 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
Default Alignment, DTC, and torque PDF's
someone asked me to post these. I don't have a site to do so, so hopefully here they are as attachments. If it doesn't work, I'll try something else
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old 11-13-2006, 02:29 PM
VetteDrmr
VetteDrmr's Avatar
Received 1,398 Likes on 749 Posts
Saved off your previous F-body and C5 info. I laminated it and mounted it to my tool box. Only problem is reading through the grease smudges from all the times I've referred to the torque info.
Thanks again, and have a good one,
Mike
Old 11-14-2006, 07:40 AM
davidfarmer
thanks for reminding me, forgot all about the F-body sheet.
File Type: pdf
Old 11-14-2006, 10:21 AM
tahoeC6
tahoeC6's Avatar
Thanks Again,
I've got my materials for the quick alignment mod for street to track that you shared a while back. Can't wait to try it!
Old 11-15-2006, 11:34 AM
Bill Hetzel
Bill Hetzel's Avatar
Hey TahoeC6, do you run at Reno-Fernley. I spend a lot of time there.
Old 11-15-2006, 10:00 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
always handy I printed it and dropped it in the service manual saves searching sometimes! Thanks Dave!
Old 11-15-2006, 10:04 PM
Indy-hp
Indy-hp's Avatar
St. Jude Donor '09
Thanks!
To Alignment, DTC, and torque PDF's
Quick Reply: Alignment, DTC, and torque PDF's
